He351cw help
Re: He351cw help
Postby Hansen01 » Thu Oct 24, 2013 10:03 pm
Good info, might have to see if i can put mine back together sometime, anyone know the efficiency range for these turbos? Right around 40 i thought
Under construction...
Hansen01
Re: He351cw help
Postby BILTIT » Fri Oct 25, 2013 8:59 am
Many folks have made more power in the low 50psi range vs 40psi on dyno runs but at expense of reliability.
I personally would keep it at 40-45psi tops.
Derek B.
BILTIT
Re: He351cw help
Postby RCCUMMINS89 » Fri Oct 25, 2013 11:11 pm
Mine ran hard up to about 45 psi.........after that....not so much
Re: He351cw help
Postby DMan1198 » Sat Oct 26, 2013 7:22 am
I've never seen a map for the cw, but the Vgt is out of its map at about 36psi
Re: He351cw help
Postby RCCUMMINS89 » Sat Oct 26, 2013 1:21 pm
Some turbos can be pushed way out of their map and still be efficient.......the Silver bullet (the true 66 silver bullet) is one of those turbos.
Re: He351cw help
Postby 92cummins89 » Sun Nov 17, 2013 11:37 am
I ran into a problem to day
Put the exhaust housing on an when I go to put the intake side on I have to undo my waste gate and the little door is on the bottom anthe valve tht controls it is on top how do I fix this
92cummins89
Re: He351cw help
Postby PToombs » Sun Nov 17, 2013 5:09 pm
You may have to make a new bracket to mount the actuator.
Re: He351cw help
Postby 92cummins89 » Mon Nov 18, 2013 7:26 am
Any ideas how I would go bout doing tht been lookin and looking can't find anything anywhere
92cummins89
Re: He351cw help
Postby BILTIT » Mon Nov 18, 2013 8:35 am
Try it with the wastegate wire-tied shut, you may not even need it. Otherwise search "spring gate", that is the best option.
I run with mine tacked shut but will be going to a spring gate when i compound it with an HT3B
Derek B.
BILTIT
