#%^ That @$^& (#^ Third Injection $%^*$@% Pump Nut ##$^#
Postby PToombs » Thu Jan 10, 2008 7:27 pm
RumbleFish wrote:I prefer to buy the $30 snap on wrench, and then sell the truck before using it. I looked for a place to use it on my gasser, but have come up with nothing so far...
Just take a torch, heat it up, and bend it straight. I bet you use it a lot then! :lol:
Postby randyswelding » Wed May 21, 2008 7:31 pm
ok so i just did mine the 1/8 method and used a cheapy 13mm wrench and bent it 90* and worked great man i gots power now!!
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby fasttalker83 » Thu May 22, 2008 4:03 pm
I bought a 13mm half moon wrench from matco tools for 13.00 to put it back on cuz all the work and time I spent taking that off I wasnt doing that again cured all my problems and it was well worth the 13.00 to me to get rid of all the hassle
fasttalker83
Postby BEARKILLER » Sat Jun 07, 2008 11:08 pm
On that hidden nut, I used a LONGGGGG extension and plain old socket; it was a straight shot back in there, once I got a long enough extension.
The only nut that actually required the Harbor Freight S-wrench was real easy to access.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby Begle1 » Sun Jun 08, 2008 7:39 am
BEARKILLER wrote:On that hidden nut, I used a LONGGGGG extension and plain old socket; it was a straight shot back in there, once I got a long enough extension.
Was that in your Ford or in your Dodge?
I could loosen it from the bottom with an extension, but when I went to tighten it, the angles were wrong and it kept torquing off the bolt.
Postby GLHS » Sun Jun 08, 2008 7:55 am
My Snap On wrench looks identical to that Harbor Frieght wrench.........except mine has a red handle.
GLHS
Postby PToombs » Sun Jun 08, 2008 5:14 pm
And cost about 6 times as much! :yuck:
Postby BEARKILLER » Tue Jun 10, 2008 5:07 pm
It was on the son's 1990 W-250
BEARKILLER
Postby Begle1 » Tue Jun 10, 2008 9:25 pm
You'd have to show me that trick. I don't remember what exactly was in the way, but something was keeping me from doing that. Injection lines, I do believe...
Postby BEARKILLER » Wed Jun 11, 2008 5:11 am
That may well be so if one is only adjusting the timing or somesuch.
We had all the lines off and out of the way, on account of we completely removed the pump.
BEARKILLER
Postby Begle1 » Wed Jun 11, 2008 8:03 am
Oh, alright.
I never bothered to remove the lines.
Postby PToombs » Wed Jun 11, 2008 4:58 pm
The rear bracket is down there too.
