2nd gen IC into '90 non IC Q's
Re: 2nd gen IC into '90 non IC Q's
Postby theoldmanW350 » Fri Mar 07, 2014 1:46 am
1990 W350. Getrag overfilled. Stock fuel. Stock turbo. M2 fuel pin. Hungry Diesel HVLP lift pump, 2nd gen IC w/ 3" Pusher Intake. Air bag set-up, onboard air. BD exhaust brake. Almost all 4" exhaust. Autometer's. Upgrades as money allows.
theoldmanW350
Postby theoldmanW350 » Fri Mar 07, 2014 3:01 am
Forgive me guys I'm still learnin' how to post pics. comotionman did you use a rad support from a later 1st gen along with the grill? I heard those psic's are really thick. Anyway thanks cmann250 for the link to the DTR post I referenced. I had to ditch my AC condenser so the IC would fit behind the center grill (still had to break out the dremel to shave down the plastic). I didn't have lower support brackets for the IC so I just fabbed up some with a small sheet of 1/16" aluminum I had. Here's the IC outlet:
I had to grind the battery tray corner for the pipe to make its way to the intake.
Here's the IC inlet:
I had to bash the inner fender well a bit with a small sledge to get the pipe to fit up.
I kept the stock throttle bracket and ground back a bit so it fit around the pusher intake:
Before:
After:
theoldmanW350
Postby cmann250 » Fri Mar 07, 2014 4:53 am
Nice work! It looks really good.
Postby Tacoclaw » Fri Mar 07, 2014 10:37 am
I agree, nice job, man. I'll keep this in mind if I ever get around to changing mine.
Postby theoldmanW350 » Sat Mar 08, 2014 2:32 pm
Hey thanks. Being a noob this project took longer than I wanted. For the other first timers out there buy your parts first! I was excited to get this IC in so started cutting before I decided to not use the 2nd gen intake (way too much grinding my throttle bracket to make it work). I had to figure out which intake to buy then wait for it to get here, then I had to figure out the charge pipes (I made my own) and how to put a bead on them, along with a dozen other little tasks I had to figure out. Anyway I'm happy with the outcome. Now it's on to the turbo upgrade.
theoldmanW350
