Afc and exhaust housing
Re: Afc and exhaust housing
Postby Tacoclaw » Thu Apr 24, 2014 2:44 am
Just find an HX35w with a billion miles on it or broken shaft or whatever, grab it cheap, and fight the exhaust housing off of it. You've got a 12cm, 'gated housing for cheaper than whatever you could get a non-'gated housing for.
Postby DodgeFreak » Thu Apr 24, 2014 10:32 am
Better hurry..http://www.cumminsforum.com/forum/98-5- ... ooler.html ...I pm'd the guy to see if he has it still.
Postby dyne_79 » Thu Apr 24, 2014 12:49 pm
Alright, here's an interesting result. Took the die grinder to the top of my afc. Looks much like the one pictured above. Ran the star wheel up as high as I could without making contact with the top. Ran more smokey and r hotter. I ran the start wheel down in half turn increments and found that it ran the cleanest and strongest with it bottomed. How does that make sense? At that setting, I actually slipped the clutch in third. Hopefully that was just because it was hot. I had been beating on it pretty hard. Egts still won't break 900
dyne_79
Postby BILTIT » Thu Apr 24, 2014 1:03 pm
Have you checked for boost leaks?
Derek B.
BILTIT
Postby dyne_79 » Thu Apr 24, 2014 3:21 pm
I have not but I don't suspect there to be one
dyne_79
