pulling the engine for a reseal
Re: pulling the engine for a reseal
Postby dazedandconfused » Fri Mar 20, 2015 11:29 am
We all have those moments. Its life with a thousand things on our minds all the time.
Postby ellis93 » Fri Mar 20, 2015 12:15 pm
dazedandconfused wrote:We all have those moments. Its life with a thousand things on our minds all the time.
Probably ^^^ simplified life would be a change of pace but boring I'm sure.
From my own experience here.....make sure that side cover pinches the gasket HARD. Mine pushed out pretty quick with a few hard runs.
Postby fatty » Fri Mar 20, 2015 12:45 pm
What side cover are you talking about? You mean the tappet cover by the injection pump?
Postby ellis93 » Fri Mar 20, 2015 1:43 pm
That's the one and only. Side cover/tappet cover.....
I actually put little spot welds all the way around the inside flange of mine,glued the gasket (again) and motored on.
Postby PToombs » Fri Mar 20, 2015 5:25 pm
A few years ago I got all paranoid because it seemed like everybody had thrust bearings going out. I checked mine and thought I had a ton of end play in the crank. So I put a dial indicator on it and found it was right in the middle of the spec. All that worrying for nothing. :lol:
Postby RCCUMMINS89 » Fri Mar 20, 2015 6:34 pm
You too? I did the same stupid thing.
Postby PToombs » Sat Mar 21, 2015 5:10 pm
Yeah, it was all standard trucks that were having problems so I freaked out. :oops:
