89 w50 still missing
Re: 89 w50 still missing
Postby Remps » Sat Jan 09, 2016 1:32 pm
The link just brings up a whole bunch of crappy running cummins for me..
Postby manostihl » Sat Jan 09, 2016 4:11 pm
Remps wrote:The link just brings up a whole bunch of crappy running cummins for me..
well wtf
manostihl
Postby manostihl » Sat Jan 09, 2016 4:12 pm
cougar wrote:Does sound like air getting sucked into the fuel line. But if you can't fine the leak I'd suggest doing a compression check. You may have a low cylinder.
where can i get a decent compression tester that i dont have to pay an arm and a leg for?
manostihl
Postby manostihl » Sat Jan 09, 2016 4:18 pm
https://www.youtube.com/watch?v=1Zk2pCCyBg4 i have it on high idle in this vid if you give it throttle while its running like this it just gets worse and starts popping
manostihl
Postby cougar » Sun Jan 10, 2016 11:49 am
The adapter I made from an old injector and line I stole off my 91 before they hauled it away. The gauges I had lying around the shop.
01 2500 "the work truck".
cougar
Postby Remps » Sun Jan 10, 2016 2:04 pm
That's weird how it suddenly starts missing like that. have you tried hooking the ksb direct to the battery so it doesn't activate, see if it makes any difference?
Postby manostihl » Sun Jan 10, 2016 6:22 pm
Ill have to do that I have my old injectors still. Did you just gut an injector and use it empty? My motor has some blowby but not enough to blow the oil fill cap off. Ill get a few little drips out of the breather hose here and there but nothing id consider major
manostihl
Postby manostihl » Sun Jan 10, 2016 6:25 pm
Remps wrote:That's weird how it suddenly starts missing like that. have you tried hooking the ksb direct to the battery so it doesn't activate, see if it makes any difference?
I know right! The truck runs good the missing continues on and off when its warm and never has a steady idle. I've had my ksb hooked to my fss ever since the fss quit.
manostihl
Postby manostihl » Sun Jan 10, 2016 6:27 pm
I know right! The truck runs good the missing continues on and off when its warm but it doesent smoke white when its warm and never has a steady idle. I've had my ksb hooked to my fss ever since the fss quit. It wire to the fss has 12 volts all the time when its on.
manostihl
Postby cougar » Mon Jan 11, 2016 11:02 am
I gutted it and ground the tip off so it was a more open hole and plugged the return hole. I use an o-ring instead of the copper washer so I can keep reusing it. The line I cut off close and flared it with a "B" nut. Works good enough.
cougar
Postby manostihl » Tue Jan 12, 2016 12:44 am
cougar wrote:I gutted it and ground the tip off so it was a more open hole and plugged the return hole. I use an o-ring instead of the copper washer so I can keep reusing it. The line I cut off close and flared it with a "B" nut. Works good enough.
Sounds easy enough to make
manostihl
Postby manostihl » Sat Jan 30, 2016 12:11 pm
the truck seems to run better and miss less without the ksb hooked to the battery? also did the timing cover gasket and crankshaft seal and found this.https://www.facebook.com/photo.php?fbid=933198643384689&set=a.337965736241319.68323.100000836870087&type=3&theater
manostihl
Postby manostihl » Sat Jan 30, 2016 12:13 pm
manostihl
Postby manostihl » Tue Feb 02, 2016 6:10 am
Can anyone see my pictures? I advanced my pump timing about an 1/8 of an inch and the truck seems to run a lot better and the miss isn't so prevalent.
manostihl
Postby spencerdiesel » Tue Feb 02, 2016 7:28 pm
Were my eyes deceiving me on the glue job......?
Was the pump gear timed at factory marks when you checked the kdp?
H1C/18
Muffler delete
spencerdiesel
