What does the thing do
Re: What does the thing do
Postby t_ruffcorn » Sun Jan 03, 2016 11:01 pm
The FF42000 is incredibly handy, easy to grab ahold of.
1993 w250 280k, 5 speed, 6x13 @80lpm, BD pin, 63/68/.80, 4200 gov, fluidampr, studs, springs, pushrods, 182/214 hamilton, W/M, steedspeed, PS I/C
t_ruffcorn
Postby ellis93 » Mon Jan 04, 2016 3:54 am
BC847 wrote:Yes.
Because they're often too cheap to fix the thing. (IMO, of course).
In my case......the leak was actually in the things electrical connection. Dripping fuel is.....uncool.
Postby PToombs » Mon Jan 04, 2016 5:23 pm
My 2nd gen was sucking air thru the plug in the fuel heater, it got old bleeding it everyday to start it the 1st week I had it. I had to pressurize the whole system to find it. I have a new heater sitting here, I never put it in. I use the block heater and cut my fuel with kerosene and haven't had any problems.
Postby Gots_a_sol » Mon Jan 04, 2016 6:07 pm
Buy this, remove heater. Problem solved, problem staying solved.
http://www.genosgarage.com/product/f-39 ... ment-parts
-Joe
Gots_a_sol
Postby spencerdiesel » Mon Jan 04, 2016 7:45 pm
Hey T ruff what did that dual filter setup run if you don't mind my asking?
H1C/18
Muffler delete
spencerdiesel
Postby t_ruffcorn » Tue Jan 05, 2016 11:19 pm
IIRC it was around 100 bucks
t_ruffcorn
Postby spencerdiesel » Thu Jan 07, 2016 4:24 pm
Where'd you plum it in on your rig?
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Thu Jan 07, 2016 5:26 pm
You take the single filter off and put on an adapter, then it takes the regular filter and a larger separator.
Postby spencerdiesel » Thu Jan 07, 2016 7:18 pm
Thanks Pete, happy birthday
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Fri Jan 08, 2016 5:15 pm
Thanks man!
Postby spencerdiesel » Tue Jun 21, 2016 12:52 pm
How troublesome is the PCM, is it ever naughty?
H1C/18
Muffler delete
spencerdiesel
Postby DodgeFreak » Tue Jun 21, 2016 1:16 pm
you can buy the nipple through Case for a whole lot cheaper if you're going to delete the housing. And I wouldnt call people that delete the heater lazy. Most states don't even need it. My truck would start fine in the winter on just the winter blend diesel. Our Diesel tractor would start with out a fuel heater. The other benefit is that it won't leak again. I'm still running the heater on my crew but my 4wd done fine without it.
Postby spencerdiesel » Tue Jun 21, 2016 2:00 pm
I think I had several brain sharts when I posted that.......I mean the powertrain control module :roll:
H1C/18
Muffler delete
spencerdiesel
