H1C 60mm compressor housing and wheel upgrade.
Re: H1C 60mm compressor housing and wheel upgrade.
Postby DMan1198 » Sun Mar 13, 2016 11:38 am
A good thing to do when putting the turbine housing on is coat it in neverseize. That'll make it come apart easier the next time.
Postby ellis93 » Sun Mar 13, 2016 4:28 pm
Ryker Carruthers wrote:Going to a 63 on an hx35... I think I'll run the 14, may put the 16 back on depending on drive pressure.
Where are you purchasing your parts?
Postby Cole92w250 » Sun Mar 13, 2016 11:03 pm
My gauge reads max @35psi of boost only one they had in stock (napa canada). Are you having black smoke issues with the 60mm Ellis93?
Cole92w250
Postby ellis93 » Mon Mar 14, 2016 4:14 am
Cole92w250 wrote:My gauge reads max @35psi of boost only one they had in stock (napa canada). Are you having black smoke issues with the 60mm Ellis93?
That depends entirely on my pump settings and foot vs load. Under normal driving conditions there is no smoking,pulling I get a haze under moderate throttle while trying to gain speed.......if I push it,sure,there's lots
Postby cougar » Mon Mar 14, 2016 8:44 am
I have the GDS 60 with the 16 on my 92. I want to go back to the 18 because of high EGT when towing. I have stock injectors, a reground M2 pin, and only slight adjustments to the pump. Boost maxes out at about 22psi.
01 2500 "the work truck".
cougar
Postby DMan1198 » Mon Mar 14, 2016 8:53 am
I feel like you'll be going the wrong way going from a 16 to an 18. The problem isn't drive pressure, it's the fact you aren't spinning the turbo fast enough at your towing rpm causing a lack of air volume, and subsequently high egts
Postby ellis93 » Mon Mar 14, 2016 6:51 pm
I agree with the above cougar ^^^^^
Postby Cole92w250 » Mon Mar 14, 2016 9:48 pm
Holy 45psi thats lot of pressure. Did you notice more bottom end?
Cole92w250
Postby ellis93 » Tue Mar 15, 2016 6:06 am
Cole92w250 wrote:Holy 45psi thats lot of pressure. Did you notice more bottom end?
That was with some honed 7x10 injectors and a nearly maxed pump/m&h m2 pin......the 7hole injectors give huge amounts of torque anyhow,so I can't really tell you anything about the effect of the turbo. I can tell you it felt real healthy. Now with the backed off pump and honed 5x10s......it works but the bottom end isn't there like with the other injectors. It's slow to spool compaired to the two.
Postby Cole92w250 » Fri Mar 18, 2016 8:02 am
did you guys put oil in the turbo beforr installing back on the mainfold?
Cole92w250
Postby spencerdiesel » Fri Mar 18, 2016 9:11 am
I would put some in the inlet
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Fri Mar 18, 2016 2:32 pm
It is a good idea. I ended up not doing it when I started mine after the compounds went on due to not having an oil squirt can, and they've been fine. They were both run previously though, so they did have some oil in them.
Postby Cole92w250 » Fri Mar 18, 2016 2:51 pm
I got the turbo off the trck and now im trying get the 21cm housing off the turbo and soaking it with penetration fluid. Its not budging. Any advice on making this easier? without wrecking the turbo.
Cole92w250
Postby spencerdiesel » Fri Mar 18, 2016 3:04 pm
Your time is probably more valuable than mine haha but I soaked mine 4 days in advance 4 times and it came right off
H1C/18
Muffler delete
spencerdiesel
Postby stillsmokin » Sat Mar 19, 2016 7:29 pm
When I first met pulltilbroke he was running 55psi out of his high tech stage 4! It lived just fine and it was non intercooled. We advanced the timing and brought the boost down to 45. He did take the thrust bearing out once, FWIW. The little holsets are tougher than people think. We currently both run HX35W turbos with the 60mm 6 blade and 12cm gated housings. I gate mine at 30 psi on the dually my egts are spot on loaded. I ran a H1C, HTT 4 at 45 psi for years, never had an issue. Good little turbos.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
