commonrail stock turbo questions
Postby oldestof11 » Thu Sep 04, 2008 12:09 pm
How about a CP3 fueling a hotrod VE? :evil:
No, in all seriousness, someone had a 1st gen head ported and polished and got a huge number increase in doing that alone. So a port job and a 3rd gen turbo might work....
Then instead of a port and polish, you might as well go for a HY-35 over a HX-55 or S300..... Cool factor has to be in there somewhere....
Postby Begle1 » Thu Sep 04, 2008 12:49 pm
I wanna do a HY-35 over a HX-55, with a big external wastegate on the HY-35.
I already got the HY, just need to install the darn thing.
Postby rattlebox93 » Fri Sep 05, 2008 9:32 am
i talked to tworline yesterday and seems to thing i would have no problems he is making me the intake tubing to fit the 3rd gen turbo the way i see it even if the stocker gets hot i can always find a used 3rd gen hight tech or industrial injection turbo for as much as a hybrid holset is new and have a lot better turbo
rattlebox93
Postby rattlebox93 » Wed Sep 10, 2008 6:32 pm
got my turbo and boost tubes from tworline excellent product by the way everyone should have those!!!! wish me luck im probly gonna need it
rattlebox93
