fuel steadly drippin out of the diaphram area
Postby bgilbert » Wed Sep 24, 2008 7:34 pm
randyswelding wrote:ok thanks KTA.i got one question if i take out the afc lever thats like takin out the fuel pin right?so then i could turn the afc shaft to the factory spot and still have all the fuel i want.
Pump top with no afc lever can and will still leak via the fuel pin/green o-ring. With no fuel pin, there's an opening in the afc bore, allowing lots of fuel to pour into the afc area and out the afc vent.
As kta mentioned, do you have a absurdly ground afc cone? That will allow the pin to enter the afc bore too far and leak fuel. Or maybe your fuel pin is worn too thin, who knows, time to part the truck out and sell the pump to me LOL.
bgilbert
Postby randyswelding » Wed Sep 24, 2008 7:44 pm
no the truck still is a 50 footer :D !with the pin and oring and hex nut (since thats all i got)in and the way grounded pin in the back, the afc pin is at its taper at the green oring so is that too far :lol:
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby randyswelding » Wed Sep 24, 2008 7:49 pm
man i can wait to get that motor and pump from cumminspride :D then i have somethin to learn on :D
randyswelding
Postby bgilbert » Wed Sep 24, 2008 8:02 pm
Sounds like you've got a couple options. 1, rotate your ground fuel cone to the stock side so the fuel pin doesn't ride out too far and allow fuel to enter afc bore. 2, do like the guy on dtr did, take the appropriate sized drill bit, 5/16" maybe, cut down to size, slightly longer than the stock fuel pin, polish it, now you'd have a longer fuel pin, with all travel and full use of afc. Go over there and look for it, should be within the first 2 or 3 pages. Just have to cipher through all the 'how do I change my tire' threads or 'what does D and W mean' etc etc...
Bill Gilbert
bgilbert
Postby randyswelding » Wed Sep 24, 2008 8:14 pm
bill i like your voice mail now thats funny oh ya and ive already saw it after i made that last post.i rotated the cone to stock and ground and stock it sticks out and ground its not even visable.how far did you grind your pin
randyswelding
Postby randyswelding » Thu Sep 25, 2008 3:52 pm
i got another pin on the way :D i think i ground my cone down a little too far,so i now know what happens when you give a redneck a grinder(thad be me)and a fuel pin cone,you get one big mess and have to get another pin :lol:
randyswelding
Postby randyswelding » Thu Sep 25, 2008 6:36 pm
dang i lost boost goin back to the factory settin on the fuel cone oh around 6psi :cry: cant wait to get the new pin in :D .oh ya and no leaky no more i ground down my pin tooo much thats for sure.thanks guys for the information ;)
randyswelding
Postby PToombs » Fri Sep 26, 2008 5:22 pm
Most rednecks would bubblegum something on the cone to build it back up. ;)
Postby randyswelding » Fri Sep 26, 2008 5:54 pm
oh no lets put it this way its about 1/16 in thick and i dont have a tig bottle yet and i got a mig but no wire,and a 1961 sa200 pipeliner that likes 3/16in rod and bigger,i know im lazzy :D and what kind of material is this pin made out of.that way i can work on it a little latter and really make a fuel pin thats really custom :grin:
randyswelding
