Valve adjustment
Postby dpuckett » Thu Jan 11, 2007 9:38 pm
Yes, at 200k yours is due.
Ok, back to the tighter lash adjustment. I have noticed a slight DECREASE in mpgs (on the order of .5-1mpg) with mine, but I havnt put enough miles on the new pump rebuild to know for sure. it could be my foot. It seems to idle sharper and with less rattle, though. So, keeping all else equal, should I get a gain or loss of MPGs? I noticed no difference in EGTs at a given boost (dont have the clutch or valve springs for an all out ful throttle run). I am thinking of putting them back to stock for now, unless someone sheds some light on this subject.
Daniel
Postby wannadiesel » Fri Jan 12, 2007 6:08 pm
I wouldn't expect it to make a difference.
Best dyno: 408/844
wannadiesel
diesel guru
Postby CDReyn » Tue Mar 06, 2007 9:01 am
wannadiesel wrote:I wouldn't expect it to make a difference.
I finally got around to doin gmine, and the oly difference I can tell is that it is running much much smoother and quiter.... :)
93 D350 ClubCab, A518, B&M Tranny Cooler, RV-HD TSS TQ and upgraded valve body, TPS by-passed and muffler is MIA...
COMANCHE TRIBE OF OKLAHOMA-----LORDS OF THE PLAINS
CDReyn
