Exhaust housing question
Postby peobryant » Fri May 01, 2009 10:03 pm
Ramrod90 wrote:So if I get the GDS upgrade, do I have to rebalance my turbo since I am swapping wheels? or is it just bol on and go.
That would be the "correct" way to do it, but most people just swap and go.
I know of at least one turbo that was trashed this way.
Postby Ramrod90 » Fri May 01, 2009 10:59 pm
Alright cool just wondering. Hey man that tire business is no joke, my truck wouldn't even start because I broke a lug stud! :lol:
90 w250 LE, pump turned up, 4" turbo back, I/C conversion, 366 GS, DennyT pin, 6x18's, BHAF, soon to come... 6" stacks and built head.
Diesel is more than a fuel... it's a way of life
Ramrod90
Postby Ramrod90 » Fri May 01, 2009 11:02 pm
How much does it cost to balance a turbo? Do they balance it as a full rotating assy. (both wheels and shaft) or just each individual piece. What I mean is, if my exhaust wheel/shaft is already balanced and I put on a new comp wheel, does the whole thing need to be balanced or just the front wheel? Thanks for all the help.
Ramrod90
Postby Ace » Sat May 02, 2009 9:28 am
The Holset upgrade part (compressor wheel) comes balanced from the factory. If a turbo got trashed after a compressor upgrade it was most likely due to some method of bad install - improperly torqued, or otherwise damaged during the install.
Ace
Postby Richie O » Sat May 02, 2009 9:32 am
It may also be because they were boostin 50 psi. and barked it in half. :shock:
