CAJUN 93 wrote:
the other thought i have is were does the extra air come from to support the added fuel. most of us are on the ragged edge with temps now. without additional air, exhaust temps would soar just the same as larger injectors.
daryl
The water vaporizes and absorbs heat, cooling the air. The meth also vaporizes and removes heat, but the main benefit of the meth is that it lets you spray more volume of liquid into the engine without putting out the fire. Cooler, denser air in = more air in the cylinder to burn the fuel = lower EGT.meby wrote:CAJUN 93 wrote:
daryl
keeping this in mind could someone explain to me again why water/meth lower egt's?
matt
wannadiesel wrote:The water vaporizes and absorbs heat, cooling the air. The meth also vaporizes and removes heat, but the main benefit of the meth is that it lets you spray more volume of liquid into the engine without putting out the fire. Cooler, denser air in = more air in the cylinder to burn the fuel = lower EGT.meby wrote:CAJUN 93 wrote:
daryl
matt
CAJUN 93 wrote:gas wont burn in that environment. the octane slows the burn down too much to generate any power and the motor won't run.
i guess my ? is will diesel fumigation increase the burn dwell time and increase hp enough to justify it's cost and complexity, especially compared to h20 meth and/or propane. my thinking is no.
Begle1 wrote:I think that a P7100 pump injecting directly at TDC, coupled with a 500HP shot of wet nitrous/ alcohol, would be crazy powerful.
seeker1056 wrote:A thought and one I will try,
Given that heat helps get our turbos spinnin I was thinkin in terms of injectin alky right at the exhaust manifold to the turbo mount to see if afterburn would speed up spool.
thoughts?
dpuckett wrote:Ok, I thought the VE's fuelling problems at higher RPM were supply related, and not limited to the capability of a hot-rodded/ modified pump. Or are we talking 5000+ as high RPM? I consider anything over about 3500 to be "high" RPM in our applications, as I would consider 2800RPM in a N14 to be "high" RPM. (I've driven stock 290s that turned 2400RPM).
If you inject at TDC, you will ALWAYS have some time delay between injection and ignition. That is why you inject before TDC- to fill the gap and make sure the fuel lights off around TDC, if not a degree or two before. There is also a short time (I'm talking milliseconds or less) between initial combustion and actual power production. Again, more reason for advance. Then you have the time from when the pump pressurizes the "system" (in this case, the injector line and injector) to when the injector pops open.
Begle1 wrote:....I want to turn my Cummins into what's essentially a gasoline engine. Does that mean that I'm kicked out of the club for good, or just until it works?
