Cooling down the turbo
Re: Cooling down the turbo
Postby Richie O » Mon Apr 05, 2010 4:05 pm
BC847 wrote:Y'all are forgetting about the heat in the bearing cartridge "Coking" the oil.
Shutting the engine down without allowing sufficient time for the turbo (entering EGTs) to cool invites issues with the oil cooking (coking) thus leaving heavy deposits
Thats why I only cool the turbo when I am messing around or towing. The rest of the time its not hot enough to bother. The other day I towed a tractor with my dads 09 dmax. I pulled in the drive and got out without shutting off the truck. He said " You left the truck running ". :lol: I unstrapped the tractor and took it off the trailer before I shut the truck off. I feel it has more to do with the temp of the turbo bearing ( center section ) then egt's. If I run 1200 degrees for 10 minutes then the turbo itself will be much hotter then a quick 1500 degree blast. I know if I did a long hard pull that within 30 or so seconds the egt will be back to normal and I'm sure the turbo is still hot as hell. I see lots of off road equipment go from full throttle to shut off many times a day. Most pit equipment operators will shut the engine off every load to do paperwork with the drivers. It goes from 100 % throttle digging to shut off. :shock:
Postby Ptothej » Fri Apr 09, 2010 9:16 pm
I agree with you.. in that the heat is trapped in the metals, and although the exhaust is down, the metal may still have the heat retained within it..
'92 W250, 5spd, reg. cab, 2" lift, 4" dp, 4"exhaust no muffler, smoke screw bottomed out, star wheel bottomed out, full power screw maxed, BD fuel pin, BD 16cm housing (30psi), K&N air filter with a modified factory air box
Ptothej
