twin turboing a ve pump
Re: twin turboing a ve pump
Postby 93d350 » Mon Sep 13, 2010 8:40 am
i understand its not going to be cheap for say. i also understand that there is better years to start with. but i own the d350 and its got low miles an i like to try to do what they say cant be done. im not one that will give up easy. i know that it will not be a over night thing to make something like this try and even try to make it work. that being said im going to atlest give it a try. ill have a egt gauge so if it gets very hot ill back off the throttle and have to rethink things then
93d350
Postby ellis93 » Mon Sep 13, 2010 11:01 am
Why would 93s not be a year to build up. Sounds funny to me.
Postby ahale2772 » Mon Sep 13, 2010 11:06 am
im not talking the year of the truck, what i mean is that its not like any of our trucks are like a duramax that you can set the tune to the first setting when you pull a trailer and level five wen you pull a sled, if you want that then get a 24v
Postby 93d350 » Mon Sep 13, 2010 12:11 pm
well the fuel screw should give you alittle bit of tuning. no its not a flip of a switch like the newer trucks but you can still turn up or turn down a ve pump. the fuel screw may not be bottemed out when towing which should cut down on the fuel flow which would make less power and heat
93d350
Postby dpuckett » Thu Sep 16, 2010 9:22 am
I'm with KTA on the towing vs hp. I have towed into the mid 20Ks, with probably 200-220hp (stock truck, pump tuning only), did just fine towing in western KS and eastern CO (kinda like Iowa- not real steep, but not super flat, either). EGTs were fine, never had to downshift for lack of power, didnt lose much speed, etc. You'd be surprised what some 3.54 gears and a good deal of low end torque will do for your towing capacity.
Not that I'm saying to NOT shoot for the moon, but the stratosphere may be all you need.
DP
Postby 93d350 » Thu Sep 16, 2010 3:22 pm
well id say my truck is as turned up as you can get it with a stock turbo and injectors but may its not. I also look at it this way if i put 5x14's in it for say and the twins dont keep up and egt are to high i could always go with alittle smaller injector and sell the biggers ones and just make alittle less power but like Dynomite Diesel said 400-500hp should be do able with enough air i no i dont need that much power to tow but who know it may not end up been a tow rig i just kno i want it to have more power then i need :D
93d350
Postby IowaCummins » Thu Sep 16, 2010 3:35 pm
where at in iowa you located?
IowaCummins
Postby 93d350 » Sat Sep 25, 2010 8:54 pm
des moines
93d350
Postby SNOOT » Thu Aug 04, 2011 4:14 pm
Richie O wrote:You will have better luck for your 400 goal with the 2nd list of mods you posted. Still being able to tow hard using all of that hp will be hard to do.
Snoot, at your power level, and all your updated air flow, can you hold the power for very long??
Sorry but I am getting caught up a little.
Richie I have no problems driving around on a 30-70 degree day but when it gets 70-90 my cooling system is working hard. The fan engages and disengages more on the freeway much more then it used to with a single turbo. I think a lot of it is from some of the additional heat being pulled into the turbo from the engine bay. My new hood should help allot.
I can run the truck pretty hard for long periods of time 70-80MPH no problems but when I push it above 80mph she starts making some heat in the cooling system. Had the truck to 110mph a few times now and it dont take long to get there.
1993 W350
SNOOT
Postby truckwrench1 » Fri Aug 19, 2011 7:11 pm
sorry i know it the post is a few days old but where is your guys timeing set if you left timeing at the stock setting and only ran a m&h spacer wouldnt you coolant temps and egt stay lower with the proper amount of air or even back the injectors down to a 5x12 or 14 instead of 5x16's
truckwrench1
Postby U.S MMA » Fri Sep 02, 2011 8:01 pm
i also have been shooting for a functional tow rig, although not at the power level you are shooting for. A custom intercooler and rad should definatly be in the order. I think a hellman cooler is around 1200, im not sure if they do radiators, but that would be the shiznit. Maybe those 5x10 southern diesel extreme's, Ive found good reviews on those. As everyone has stated, different parts of the country require different things out of a truck. Up here, grossing about 15k, cab over, trailer with 4 sleds and gear, I can pull 7-8% grades all day at 60mph, not fast nor heavy i know, but in commifornia where i came from, id be limping up a hill in 3rd at 40 mph with that load. 20 degrees vs 90 or worse.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
U.S MMA
Postby rockbuggy4x4 » Tue Apr 09, 2013 3:56 pm
SNOOT wrote:Had the truck to 110mph a few times now and it dont take long to get there.
:hs: :notfair:
WOW!! My '89 only goes 65 on a good day. 70mph down hill with my rockcrawler. Its all stock with minor pump tweaks. Am I doing something wrong??
rockbuggy4x4
Postby cmann250 » Tue Apr 09, 2013 4:40 pm
Nope, that ain't good, but it can be easily and cheaply fixed.
Make a thread about the issue and we'll gladly help you out.
Nothing personal, but it's nice to keep threads somewhat organized so it's easier to track down info later.
