oldestof11 wrote:O ring on back side of pump ksb cover. Mine did that and then it eventually blew out.
RCCUMMINS89 wrote:I had a leak back there when I originally bought the donor truck. It didn't affect starting or idling on my mess, but it would make sense as the injection pump would lose some prime
RCCUMMINS89 wrote:um..... if it was leaking when it was running, then yes it would definitely have an affect at advance in the upper rpm.... as the fuel required to push on the piston is just leaking out.
RCCUMMINS89 wrote:I hope this was actually causing issues.... on my truck it wasn't, it just leaked a gallon a minute.
