POP goes my head gasket, help needed quick
Re: POP goes my head gasket, help needed quick
Postby Hansen01 » Thu Oct 27, 2011 9:49 pm
collegekid wrote:ok thanks, mines been leaking there for a while now, replaced the copper washer and the horseshoe washer on the return line, still leaking pretty good, up through the retaining nut....must be a cracked head? (sorry not trying to hijack the thread)
hijack away :D
Under construction...
Hansen01
Postby Hansen01 » Sat Oct 29, 2011 8:26 pm
hope to have it together and running tomorrow sometime, any advice on torquing the head studs? once cold and once hot is what i understand, got the rocker arm pedestalls milled down for free :D cus my uncle has a mill,lol took him aproximately and hour and he wasnt working fast lol
Hansen01
Postby BC847 » Sun Oct 30, 2011 8:41 am
Do you have access to a digital torque wrench?
Postby Hansen01 » Sun Oct 30, 2011 10:44 am
Yup
Hansen01
Postby Hansen01 » Sun Oct 30, 2011 6:07 pm
well... it started and ran!but had a slight knock, well a huge knock, scared the crap outa me(thought it was gonna blow up loud),lol but we got it figured out now, pushrod was not set in correctly and bent the crap out of it, hope to have a new one in a day or two, then hopefully it runs without any big noises :?
Hansen01
Postby Mark Nixon » Mon Oct 31, 2011 6:27 am
I'll give you one. :D
Or how about a dozen? :lol:
Postby Hansen01 » Mon Oct 31, 2011 8:17 pm
lol thanks Mark, but dad had one at work, got it all together and running tonight! sounds even better than befor and it spools up much better, they had to replace all 6 nozzles on my injectors so apparently they was pretty bad
thanks guys! :D :D
Hansen01
Postby Hansen01 » Mon Oct 31, 2011 8:25 pm
also it does not haze at an idle anymore :D
Hansen01
