by Mark Nixon » Thu Feb 14, 2013 12:07 pm
STORM is the abbreviation for the design of the block.
The letters mean "Standard Thread O Ring Metric", which, IIRC is in reference to the main cap bolts, which are 12mm on a STORM block and 14mm on the 1st gen and most 12 valves.
The STORM block is, generally speaking, a 1998-2002 24 valve block (And some industrial apps much later), but as you've probably figured, some later 12 valves have the STORM block, also.
Generally speaking, it's not usually a big issue on the very earliest blocks used in the 12 valves, I can only recall ever seeing 2 that were cracked and both were the large "53".
If yours doesn't have a large (3/4 inch tall, or so) "53" anywhere on it, don't worry about it.
If yours DOES have the big number "53", but it's also over 200,000 miles, don't worry about it, either.
There is another version of "53" block, but I have NEVER ever seen one of them broken.
They have a smaller "53" cast in under the A/C compressor mount, near the water outlet.
You have to remove the A/C bracket to see it.
