1990 Exhaust Housing?
Re: 1990 Exhaust Housing?
Postby BILTIT » Mon Nov 28, 2011 10:16 pm
A search will find lots on he351, i am currently installing one.
Derek B.
BILTIT
Postby Hansen01 » Tue Nov 29, 2011 6:01 am
ive heard alot of good things about them on first gens, i should have asked mark if i could test out the one he had for a week :roll: there 60-60-9 if i remember right
Under construction...
Hansen01
Postby thrashingcows » Sat Dec 03, 2011 9:45 pm
What injectors are you running? Could you have bad injectors, leaking etc? You will run more EGT's with leaky injectors.
thrashingcows
Postby Hansen01 » Sat Dec 03, 2011 11:28 pm
stock non intercooled injectors, they all just had new tips put on em and rebuilt about a month ago
Hansen01
Postby m880cummins » Tue Dec 06, 2011 7:42 pm
I love the quick spooling of the HX35 on my NON-IC truck. The intake pipe is a culprit right now though. I only saw 14psi at first but then ported the stock intake and got 16psi but now thinking about a 2.5-3" tube intake pipe...I REALLY want to see 30-35 psi! The stock H1C I had made 26psi so this is a little depressing.....
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby Hansen01 » Tue Dec 06, 2011 9:20 pm
i was making 40 before i put an intercooler in it, and that was with 3in pipe i agree 16 is a little depressing :roll: any room left on your full power screw?
Hansen01
Postby Tacoclaw » Tue Dec 06, 2011 9:33 pm
Or boost leaks?
14psi is bad, as in something is wrong bad. Does the compressor housing have an o-ring or anything that connects it to the center section? In a non/IC'd setup, there aren't many places for leaks to happen. :?
Postby thrashingcows » Thu Dec 08, 2011 12:07 pm
I agree 14-16 with a HX35 and a 12cm housing. Is your wastegate stuck open, or not set-up properly? You should be spooling that baby up past 25lbs no problem.
thrashingcows
