by bmoeller » Tue Apr 10, 2012 5:28 am
Hansen01 wrote:bmoeller wrote:Hansen01 wrote: and it is almost always making boost, so theres not hardly any lag, overall i say it was a great upgrade
Bye-bye good mileage.
i understand where your comin from on the bad milage part, but it runs cooler by 100 degrees on the highway (600 degrees) and in tern less heat= better milage?plus the motor sounds like its hardly even working compared to before
The engine doesn't have to "sound" choked down to be hurt by it. You can choke a HE351VE down enough to spool like lightning, and the EGTs are no lower than they were with the stock H1c with the 21housing. Mileage went from 20 , to 14.5mpg. Only real gain I've had from it is cleaning up the smoke a bit. Peak and cruising EGTs really haven't changed either. I can make almost 10psi more boost, but so what.
NEW- '82 CREW cab dually. Cummins, NV5600, 205, D60/D80.
Work in progress......
SOLD- '99 3500, SO CTD, 5spd
