replacing head,do I need the head studs?
Re: replacing head,do I need the head studs?
Postby RCCUMMINS89 » Thu Feb 07, 2013 1:41 pm
I would....for the xtra $250, well worth it and you shouldn't ever have to worry about it again (SHOULDN'T)
Postby skilletky » Thu Feb 07, 2013 1:51 pm
RCCUMMINS89 wrote:I would....for the xtra $250, well worth it and you shouldn't ever have to worry about it again (SHOULDN'T)
x2. if you plan on running how you have been when you popped the gasket, i would definatly o ring it or you will have more money in head gaskets than what it cost to do it. i went through 3 head gaskets (2 in less than a month) before i had it oringed.
skilletky
Postby rockmike » Thu Feb 07, 2013 2:15 pm
skilletky wrote:are you gonna have it oringed?
Negative,im out of money and dont have time to wait on the machine shop...ive always wanted a boreing head for my mill so maybe down the road I'll research how to do it right myself and get the boreing head to do it.I got a nice 10" rotary table but this head is way to long to make a rotation on the table.
I bet I could build tool to do the ring groove,I machined my own injection line removal tool to pull the lines at the pump...worked good! 8)
Then later I can have my old head ported and polished,decked and ringed the gaskets arent to expensive.Then slap on my new H.P. head on the engine if im lookin for more power or a project.
But right now I just need to get this truck put back together so I can get to workin on my rock buggy thing and have it ready for Moab the end of March.
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Postby rockmike » Thu Feb 07, 2013 2:20 pm
I KNOW this is great advice and do appreciate it guys,truley DO! im going to put this new head on with ther ARP's tune her down just a bit for my trip to Moab.
I really want to put a differant cam in it...im sure with the lack of ZDDP in the oil these days the cam is showin some wear,at this time will be a great time to have the other head ported,decked and ringed then get back to pumpin this rig up some more...its so addicting isnt it lol
rockmike
Postby RCCUMMINS89 » Thu Feb 07, 2013 2:23 pm
Uh....oh....sounds like I have some more 1st gen competition in my neck of the woods.
Postby rockmike » Thu Feb 07, 2013 3:30 pm
RCCUMMINS89 wrote:Uh....oh....sounds like I have some more 1st gen competition in my neck of the woods.
lol yeah right! Youre knowledge base on these rigs makes me look like the newb that I am.I really appreciate you guy sharing your wealth of knowledge with newbs like me.
rockmike
Postby rockmike » Fri Feb 08, 2013 10:59 am
So the heads off,This engine has 310k on it and it has a perfect cross hatch pattern on all 6 cylinders still :shock: is this common? to have NO cylinder wear @ this mileage?
So whats this yellow chalk lookin stuff?
100_0588 by ffolted, on Flickr
100_0589 by ffolted, on Flickr
rockmike
Postby rockmike » Fri Feb 08, 2013 11:05 am
WTH are these weird lookin pistons? lol aint never seen nothin like these :shock: is that bowl in there supposed to be like a lil oven? what up with the d ick head thing in there,its offset toward the inj....spray deflector?
100_0593 by ffolted, on Flickr
Its crazy to me that this all the air this engine gets through this weee lil air horn...
Do we see a HP increase swapping this for say a 24 valve unit?
100_0594 by ffolted, on Flickr
Thanks guys.
rockmike
Postby RCCUMMINS89 » Fri Feb 08, 2013 11:14 am
LOL...that's the bowl that the boom actually takes place in
Cross-hatch....yep normal, when you don't have it anymore it's not good. I got a 2 cylinders that don't look brand new anymore.
As far as the yellow??????????????? Maybe it's a water/meth thing.
Postby rockmike » Mon Feb 11, 2013 10:06 am
:evil: The head swap is not going so well!
I bought a loaded ready to install head.I oticed one of the intake valve keepers wernt seated correctly...I just happen to have a valve spring compressor Ibought at a yard sale a few years back so...
The keeper has a bur on the inside of it so thats why it wont allow the vlave cap to seat.Upon further inspection I notice theres MASSIVE casting burs and metal and grit stuff everywhere inside this head! :x I'll post some pics.So I spent my only day off breaking this head sown and I went in and cleaned up all the casting flash? whatever you call it,smoothed out the exhaust ports and water galleys.Then I went a head and numbvered all the valves and lapped them in with some lapping compound and a lil suction cup hand lapper and put it all back together.
So now im right back where I started...but at least I know what I have and can trust my engine is not going to get filled with CRAP!
If I had not noticed that retainer,if that retainer wasnt screwed I may have not checked the inside of this head! my motor would get filled with metal and grit sthi from the casting.
I recall an old saying..."trust but verify!"
rockmike
Postby Bob L » Mon Feb 11, 2013 12:33 pm
” Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense.”
- Buddha
Bob L
NRA Life Member 1974
'92.5 D250 LE EXT.CAB...Getrag...All Original...No Rust...
Purchased new in late Oct.'92---128K Mi. Still Like New.
Bob L
Postby RCCUMMINS89 » Mon Feb 11, 2013 12:50 pm
Anything that comes from Buddha is utter non sense. Whether it makes sense or not.
Postby rockmike » Wed Feb 13, 2013 11:17 am
I finally got some pics uploaded.I got all the ARP head studs set now,had to bottom tap all the block holes to get the ARP's to set at the required heighth.Im ready to start maching the rocker holder now...
Heres some pics of that new head I bought.
At least they put in the nice steam seals.
The pics dont show it that well,can you see the casting lip in the runner
All the exhaust ports had this step machined in them,big sharp edge!
I knocked that off there.
later I came back in there and blended that in real nice and smooth.
All the holes had some very sharp jagged edges behind the valve seats,I cleaned them up and rounded the under side of them.
Then I went in and hand lapped all the valves in,a comparison the left one is lapped...
rockmike
Postby rockmike » Wed Feb 13, 2013 11:22 am
gettin stuff cleaned up and painted.
Took the time to tape off the factory stciker 8)
I ported the turbo and exhaust manifold to match the gasket.
I enjoy doing this kinds stuff,just tinkering out in the shop 8)
rockmike
Postby RCCUMMINS89 » Wed Feb 13, 2013 12:18 pm
Wanna do mine? Seeing is how you enjoy it?
That looks like a crack in that last picture of the head.
