1989 dodge w350 missing under load
Re: 1989 dodge w350 missing under load
Postby RCCUMMINS89 » Mon Jan 26, 2015 1:18 pm
Measure the diameter of the tip stock are 9mm
Postby manostihl » Mon Jan 26, 2015 1:39 pm
RCCUMMINS89 wrote:Measure the diameter of the tip stock are 9mm
there no way to tell if they are an upgraded injector though ? like marines
manostihl
Postby manostihl » Mon Jan 26, 2015 2:34 pm
i guess an upgraded would be a 7mm duh sorry for the dumb question theyre definately stock then i measured 9mm
manostihl
Postby RCCUMMINS89 » Mon Jan 26, 2015 4:03 pm
There are a 5 hole (not stock) available for them.... but highly unlikely. If they are 9 and have 4 holes.... they are stock.
Postby manostihl » Mon Jan 26, 2015 4:09 pm
RCCUMMINS89 wrote:There are a 5 hole (not stock) available for them.... but highly unlikely. If they are 9 and have 4 holes.... they are stock.
theyre stock. why wouldnt the 5 hole be likely. how do you guys do a compression test on these motors?
manostihl
Postby RCCUMMINS89 » Mon Jan 26, 2015 4:27 pm
I don't know of any company that sells the 5 hole 9mm shank injectors.
Postby AHineman » Mon Jan 26, 2015 6:03 pm
I've got a snap-on compression tester with the adapter for the 12v cummins. I bought (ordered and returned) and or borrowed a couple of cheaper sets that were supposed to have the right adapter, but none had the correct pieces.
Postby manostihl » Mon Jan 26, 2015 6:31 pm
got a picture of it? i just priced out a rebuild and testing them at the only diesel injector shop around here. they charge 42 bucks to test all of them and 390 to rebuild.
manostihl
Postby AHineman » Tue Jan 27, 2015 4:15 pm
I'll get a pic later this evening.
Postby AHineman » Tue Jan 27, 2015 7:43 pm
Postby manostihl » Tue Jan 27, 2015 9:04 pm
Well I tried a compression tester you just push into th hole and I can't hold the Damn thing over it lol. But I noticed something else. The injector pump is still shooting fuel out where all the lines bolt in despite having no power to the fss and even when i hold the stop lever. ????????
manostihl
Postby RCCUMMINS89 » Tue Jan 27, 2015 9:11 pm
You'll always get some fuel. If you didn't you could fry the h/r assembly with an fss failure.
Postby manostihl » Tue Jan 27, 2015 9:20 pm
RCCUMMINS89 wrote:You'll always get some fuel. If you didn't you could fry the h/r assembly with an fss failure.
h/r assembly? Sorry I'm new to these terms. My fss switch has been on the fritz for a while. It only recently started working properly for whatever reason Idk
manostihl
Postby manostihl » Wed Jan 28, 2015 11:03 pm
i pulled my afc cover today to look at where the fuel pin was set to and notice that someone lost one of the copper washers for the banjo bolt on the boost tube and replaced it with a little paper gasket that was trashed when i pulled it. so i dont know if that would make a difference also :?: :?
manostihl
Postby RCCUMMINS89 » Wed Jan 28, 2015 11:14 pm
h/r assembly is the "distributor" or what distributes the fuel. Your fss being on the "fritz" lately may or may not lead to the problems suggested.
As far as the improper fix... that will cause a loss in power, but not a missing under load situation.
