Power woes....
Re: Power woes....
Postby oldestof11 » Thu Apr 09, 2015 2:36 pm
Put a proper wastegate on it. Trust me, it is much more fun
Re: Power woes....
Postby Hansen01 » Thu Apr 09, 2015 5:29 pm
I also thought about that too, if I remember correctly it didn't fit tho am I wrong?
Seems like it hit something
Under construction...
Hansen01
Re: Power woes....
Postby Hansen01 » Sun Apr 12, 2015 6:16 pm
Ok, got some good news, and the same ol same ol news
Put the Wastegate on, to hold it shut, (capped the line from turbo) and the good news is that my egts are down to 1300 ish at wot
Same ol same ol news is that I'm still at 36 lbs
Hansen01
Re: Power woes....
Postby oldestof11 » Sun Apr 12, 2015 6:29 pm
Still have the solenoid?
Re: Power woes....
Postby Hansen01 » Sun Apr 12, 2015 7:02 pm
On the turbo? It's on there but not hooked up to anything
Hansen01
Re: Power woes....
Postby RCCUMMINS89 » Sun Apr 12, 2015 7:32 pm
Hook 12 volts to the solenoid. See if anything changes. Just for kicks.
Re: Power woes....
Postby Hansen01 » Sun Apr 12, 2015 7:37 pm
10-4 I thought I read somewhere when they have 12 volts it will open the gate at around 40 but, not for sure, that was a while ago I'll have to try it
Hansen01
Re: Power woes....
Postby RCCUMMINS89 » Sun Apr 12, 2015 9:40 pm
That's correct. Way back when I first put a 351 on.....I tried to close the gate, etc...... I couldn't get over 30 psi.... ran 12 volt power to it, and was at 43 psi.
Re: Power woes....
Postby Hansen01 » Mon Apr 13, 2015 3:18 pm
Wired it up to 12v not really much change may have gotten up to 38 39lbs
Still have some extra fuel up top I think, definitely have it on the low end.
Idk might take the intercooler out re gasket all the intake gaskets on the engine and start over...
Hansen01
Re: Power woes....
Postby oldestof11 » Mon Apr 13, 2015 3:27 pm
At least you are getting MORE now. Put a boost elbow on there now.
Re: Power woes....
Postby Hansen01 » Mon Apr 13, 2015 5:06 pm
An elbow on??? The turbo?
I guess that never crossed my mind if I put my gauge line over on the turbo it would tell me if anything ahead of it is leaking correct?
Hansen01
Re: Power woes....
Postby oldestof11 » Mon Apr 13, 2015 5:11 pm
It will tell you if your IC is leaking.
Boost elbow: Used to restrict boost getting to the wastegate effectively raising the required pressure to open the wastegate.
Re: Power woes....
Postby Hansen01 » Tue Apr 14, 2015 7:28 am
Ahh gotcha at the moment it's got a hose, a bolt,2 clamps and some silicone as my boost elbow so I could be sure that it's not opening the wastegate ;)
Hansen01
Re: Power woes....
Postby PToombs » Tue Apr 14, 2015 4:44 pm
oldestof11 wrote:It will tell you if your IC is leaking.
No it won't. It doesn't matter where the gauge is, it reflects the system pressure. If the IC is leaking the pressure won't build anyplace.
Re: Power woes....
Postby Remps » Fri Apr 17, 2015 10:53 pm
Anyone ever put a boost gauge on compressor outlet and the intake manifold at the same time to see if there was pressure drop on an intercooled setup?
