90cummins wrote:I'm in line for a 14mm head from KTA and i'm looking for new injectors. i've looked up buddha power injectors and scheid diesel and haven't really seen prices for custom injectors but i'll be honest i'm not looking forward to shelling out for them but i've also seen some pretty reasonable prices for other sticks. Anyone know anything about Pure Diesel Power's Stage 5s: http://www.puredieselpower.com/catalog/pure-diesel-power-435hp-9498-59l-cummins-valve-injectors-p-2696.html They look like they would sure move alot of fuel, any idea how they would do with the 14mm head? If I were to have new era make me a set for 700 what should they be, as far as size and spray pattern??
I ran POD's, hx35 and a 14mm head for awhile with no problems, other than a sky rocketing boost gauge. The right foot controls all. I see no problems running POD's and a 14mm head... other than low HP . I switched out my POD's to a set of 6x16's from Scheid and gained 10psi of boost without changing anything else.
I also ran stock fuel lines, and a piston lift pump with a 14mm head with no problems, made 443hp with a s300 and that setup.
Maybe I'm just lucky with my 14mm head. I should have the twins done by mid-summer, so hopefully I can finally break 500rwhp .
cummins king wrote:how many miles you do with the 14mm and the setup, was it a daily driver
thanks
ck
