THE ULTIMATE FUEL MILEAGE THREAD
Postby KRB64 » Sat Feb 17, 2007 10:15 am
KTA wrote:I write my fuel stops in a logbook. When I fill up I note the mileage and how many gallons. By doing this I can average fuel mileages for months or years, all I have to do is add up the miles and the gallons used for that time period and divide it out to get my mileage. :P
Thats what I do but my speedo is off by 5mph so my mileage is off a liitle too. I'm going slower than what it says, so that means I'm not traveling as far which means my mileage is actually a little worse than what i calculate. :cry:
'92 W250 CC LE, auto, OD on shift, 3.54 limited; boost/PT pyro/tranny, oil temp, fuel press, tach; Bosch 190s, Ol' Smoky, 366 spring, full fuel, pull cable, 1/8" bump, synthetics, Borgeson, aFe, 16cm house, 4" pipe, AT cooler, ton shoes, ext reg...
KRB64
Postby RumbleFish » Sat Feb 17, 2007 10:22 am
I practically never check mileage, but here is the few times I have.
#1 D250, manual, 3.54, 235/85/16's, stock injectors, virgin pump (yeah, it's a dually now, but haven't checked the mileage since the conversion)
18 mpg on summer fuel around town
21 mpg on winter fuel heading south of Indy to pick up a turbo kit for my old neon. Ran 75-80 mph most of the way.
23 mpg on summer fuel going to Tire Rack in South Bend to pick up slicks for autocrossing. Ran 70-75 most of the way.
Postby dpuckett » Sat Feb 17, 2007 9:03 pm
Mine- #6- 17mpg city(<45mph 90% of the time, hardly gets warmed up); 19-21hwy. 92 D350 Xcab, steel flatbed, 3.54
Mom's #6a- 15mpg city; 17-18hwy. It just got a refresh on pump and injectors, so it hopefully will improve. 92 D350 xcab, p/u bed, 3.54
Daniel
Average Fuel mileage...
Postby Bluebird » Mon Feb 19, 2007 1:49 am
#5a: From 32-fuel stops, the average fuel mileage calculated is 20.05mpg. I use Power Service fuel treatment approximately every 50-gallons used. See my signature for speed and truck mileage.
1993 Patriot Blue reg-cab CTD D250 LE; auto; 3.54LSD;BHAF; 3" straight-pipe/14:Magnaflow; MagHytec diff-cover;ARE lid matches hood; 222,000 and rolling; 133HP/311TQ; 17-23mpg.
Bluebird
Postby Dean » Tue Mar 13, 2007 8:00 pm
I was just going to ask what you guys with DRW's get for fuel mileage and I saw this post.
When my truck was a SRW I got averaged about 19-21 mpg. Now that I have converted it to a DRW, the only time I checked it I got about 13 mpg. I noticed that my fuel mileage when way down when I made it a DRW but I didn't think it would be that bad.
Dean
Dean
92 W350 5 speed, F-450 rear frame sectioned on with Dana 80 rear, 370 injectors, HTT stage 4/16cm, Pump and timing bump, Hydro disk brakes, Porsche e-brake, Small sleeper for my dog, Alu flatbed.
Dean
Postby JLeonard » Wed Mar 14, 2007 9:19 am
I'm a number 1 :D
Best I got was 25 + (on several occasions I might add).
Typical in summer 22/23
Typical in winter 20/21
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
