1st gen vs 2nd & 3rd
Re: 1st gen vs 2nd & 3rd
Postby Ironforger » Sat Apr 06, 2013 7:34 pm
ellis93 wrote:Good find, watch out for that dash...breath on it and it'll break into a thousand pieces :lol:
Buy an airdog fuel supply system and that VP44 will live just fine
Man you are so right. There is a crack in the dash and I just touched the cracked bezel and a piece broke off like a stale potato chip.
Which airdog product should I get? I'm not quite understanding the issue. Is there an in-tank fuel pump? Or should I get the raptor lift pump kit? http://www.pureflowairdog.com/frrp.php
They have quite a few things avail for my model year. http://www.pureflowairdog.com/dodge-mak ... php#raptor
FOR SALE --> 1990 W250 5sp reg cab. 21 mpg. Aprx 145k. (odo broke last year) Fuel screw. KDP killed. Solid floors, rockers & cab corners. Pm me.
FOR SALE --> 1995 Izuzu NPR 16ft Morgan body/side door. 160k. 80 k on reb auto trans. 1 ton lift gate. Pm me.
2002 3500 6 sp Qaud cab 2 wd. 202k <-- One badass truck!
1999 VW beetle tdi. PP520 injec. Rocketchip st. 3. 45 mpg. 260k
Ironforger
Postby RCCUMMINS89 » Sat Apr 06, 2013 7:45 pm
are you going to ever get more out of it.....performance wise?
Either way, pm me with what you want and I'll send you some quotes on what I can do price wise.
Postby ellis93 » Sat Apr 06, 2013 7:50 pm
Buy the whole kit,the replacement module(if you have the intank pump) and draw straw,line,pump/filter unit. I've installed several of these thing and I have never had any issues out of them. The pump kits come with two different pump regulator springs,you need to use the lowest psi rated one. If you don't it'll make the truck a beeeoch to crank. The VP pump is a strange bird...not enough fuel and it eats itself,two much (anything over 17psi) and it turns into a cold natured carb feed Chevy,cranky cranky cranky cough spit sputter run :lol:
