1989 dodge w350 missing under load
Re: 1989 dodge w350 missing under load
Postby manostihl » Thu Jan 29, 2015 2:38 pm
RCCUMMINS89 wrote:h/r assembly is the "distributor" or what distributes the fuel. Your fss being on the "fritz" lately may or may not lead to the problems suggested.
As far as the improper fix... that will cause a loss in power, but not a missing under load situation.
I see. What i meant by on the frits was most of the time it wouldnt shut off with the key but occaisonally it would. It only just recently started shutting off with the key all the time. Never shut off while i was driving except one or two times when i was driving down the expressway and the wire fell off the fss but that was a while ago.
manostihl
Postby manostihl » Thu Jan 29, 2015 5:26 pm
how could the fss simply not working mess up the h/r assembly?
manostihl
Postby manostihl » Thu Jan 29, 2015 7:03 pm
Any way to test the pump
manostihl
Postby manostihl » Sun Feb 01, 2015 12:18 pm
Figured it out! Two holes on two injectors were plugged
manostihl
Postby AHineman » Sun Feb 01, 2015 12:45 pm
Awesome. Glad you got it fixed.
Postby RCCUMMINS89 » Sun Feb 01, 2015 10:06 pm
Nice
Postby manostihl » Mon Feb 02, 2015 5:11 pm
thanks for all your guys help anyway. i definately learned some things
manostihl
