Mysteriously died?
Mysteriously died?
Postby scotts_d250 » Tue Jun 07, 2011 9:13 pm
Heya all I'm new here and this is my first post i was referred here by a buddy of mine... For the past two weeks i have been having troubles with my truck's fuel delivery. On the way home i was sitting at a stop light and I noticed the truck was missing and had a big lack of power. So i babied it home, put in a new fss and fuel filter (my old fss was bad), i re-bled multiple times and i couldn't get it to run. It wouldn't catch and when it would it would die immediately. From there i pulled the injectors and had them tested and i found that #1 was hanging open and the others pop pressure were low.. So I hastily ordered new injectors and today i put them in, bled and tightened everything up... First crank it wouldn't catch unless i had my foot on the pedal. This symptom kept repeating itself, so i went out and got a new lift put and installed that. After re-bleeding and installing my LP it started right up but ran pretty rough. I bled the injectors and it smoothed out a little bit but it wouldn't get to where it used to be. At higher rpms than idle, it seems the miss would go away and it would smooth out. I noticed around #4 and #5 injectors the hold down nut looked bubbly, i know i tightened it down pretty tight but tomorrow im going to check. I took it out for a test drive to see if it would self bleed itself. I noticed it was a little hazy and when i first started it smoked a lot but then cleared up. it looked to be gray, but it was pretty light. It did alright for most of the way until it suddenly died on me, It sounded like it was running on 2 cyls, I shut it off and pushed it back. Being out of day light i had to take a break.. Any ideas of whats wrong? I'll be triple checking for air leaks tomorrow. I get fuel at all injectors from my IP... But could it be my ip isnt pushing enough? its a bone stock truck with about 220k on the clock... 1991 intercooled with the recall service pump.
Sorry for the long post everyone.. Its my daily....
I appreciate it and i'll give back the first chance i get.
scotts_d250
Re: Mysteriously died?
Postby thechoochlyman » Wed Jun 08, 2011 11:02 am
Lift Pump.
'89 D350 - Denny T Stage II, 366 GSK, HX-35, Powerstroke IC, Power Screw 1/2 turn from runaway, 2nd gen seats, 35% tint, Sony Head Unit, 4" Exhaust, Replaced everything replaceable.
B O T T S R
thechoochlyman
Postby scotts_d250 » Wed Jun 08, 2011 1:14 pm
I suspected that and it put a new one on.. it died with the new one on it. I'm make a line and fitting to go in the place of the line to the Ip.. and put it in a jar and see if im sucking air it before or after the LP and see if my tank is clogging or anything
scotts_d250
Postby IowaCummins » Wed Jun 08, 2011 3:43 pm
was the fuel shut off plunger broken? like the rubber tip missing? i chewed up two of em and i pulled my delivery valves and cleaned out a few little chunks of rubber just sitting in them.
IowaCummins
Postby scotts_d250 » Thu Jun 09, 2011 2:10 am
I saw metal shavings on the shaft of the plunger and the rubber tip was complete. I thought the shavings were from the solenoid it looked like the o-ring stopped most of it.
scotts_d250
Postby scotts_d250 » Wed Jul 06, 2011 9:55 pm
Solved: Springs in the pump were shot, Installed a new pump.. Spins like a top, Its a whole new truck, runs better than it did new.
scotts_d250
