the smoke screw fell out of my truck so i put the right length bolt in place of it, keep in mind ive never had my fuel pin working since ive had my truck but anyways im not getting any more fuel when my whopping 21 lbs of boost
thanks
Tacoclaw wrote:The pin will come out when you move the throttle, even with the engine off.
If it's showing a track all the way down the cone, then it's working as intended. Maybe you're just too power-hungry.
mathews8pt wrote:One VE pump i worked on was so gummed up that the little pin wouldnt move at all! The truck had NO power!
Took the top off, cleaned everything REAL GOOD and it worked like it should. Sounds like your on the right track
