where is the coolant temp sending unit?
Postby 92strokersmoker » Wed Jun 22, 2011 3:17 pm
My temp guage is all haywire and im looking for the sending unit to replace it? Could someone point me in the direction?
92 w250 NV4500, Denny T stage II, HE351, 5x.012, FPS maxed, 3200 spring, 1/4" timing bump, ALL guages, Carter fuel pump. And some more
92strokersmoker
Re: where is the coolant temp sending unit?
Postby Richie O » Wed Jun 22, 2011 4:17 pm
Drivers side, rear of the engine. Its fun to get to.
Postby cmann250 » Wed Jun 22, 2011 4:19 pm
Right by the fuel filter iirc. Yes a PITA too
Postby 92strokersmoker » Thu Jun 23, 2011 3:58 pm
awesome im so excited now....(sarcastic tone of voice)
92strokersmoker
Postby PToombs » Thu Jun 23, 2011 5:48 pm
I found mine when I pulled the head off. Well, tried to. It came forward about 6 inches and then stopped. I was like, WTF? What's that wire? Awww, siht! :(
Postby Richie O » Thu Jun 23, 2011 6:14 pm
I found mine when I pulled the engine, tranny, and transfer case off my 93 frame and the rope got caught on it and SNAP!! O crap, 75 dollar NO NO. :lol:
Postby PToombs » Thu Jun 23, 2011 6:18 pm
I was lucky, I bent the plastic and cracked it. I checked it with the multitester and it show continuity so I put some silicone in the cracks and ran it. It works, so I got lucky. 8)
Postby cmann250 » Thu Jun 23, 2011 6:41 pm
I must be thinking of the wrong thing. (where is the smacking the forehead smilie?) Im thinking oil, not coolant.
Postby 92strokersmoker » Wed Jul 13, 2011 3:51 pm
I got a question, I noticed that the wire going to the sensor comes out of the harness that also has the wires for the speedo. Both my speedo and coolant temp guages are giving me eratic readings, my temp guage just goes hay wire at a million miles an hour along with my speedo. Im wondering if its a bad ground issue but I keep looking for grounds and cant find any. The ones I know of look fine. Before I drop money on a new sensor, Do ya'll think it sounds like a wiring issue or a sensor?
92strokersmoker
