IP specs.
IP specs.
Postby dragrdan » Tue Jul 05, 2011 2:56 pm
Could someone with a manual, or access to Esi-tronic, tell me if Bosch gives a spec for clearance on the head and rotor.
93 W250 5spd, Comp 275, HE351CW, 5X18, IP turned up, 3200 spring, BHAF.
dragrdan
Re: IP specs.
Postby dragrdan » Thu Jul 07, 2011 4:10 pm
nobody?
dragrdan
Re: IP specs.
Postby BCRick » Fri Jul 08, 2011 4:35 pm
The factory manual does not go into the IP. Past adjusting the idle it says to the shop.
'89 W250, Reg Cab LE, kdp killed, 366 spring, fuel screw turned up, tach, boost, pyro, aux tank, upgraded lights w/ relays, 8000 # winch.
BCRick
Re: IP specs.
Postby Mark Nixon » Mon Jul 11, 2011 3:48 pm
I'd about bet that the clearance is in the tenth of thousandths range (.00010) or tighter.
Re: IP specs.
Postby dragrdan » Wed Jul 13, 2011 2:01 am
I know it is close, but there has to be a specification.
dragrdan
Re: IP specs.
Postby Begle1 » Thu Jul 14, 2011 10:01 pm
Hmmm....
Lapped finish?
Re: IP specs.
Postby Mark Nixon » Thu Jul 14, 2011 10:17 pm
I think someone should be the unlucky guy to test a 13mm H&R.
Anyone know of a mildly burned 14mm rotor to get machined?
Re: IP specs.
Postby Mark Nixon » Thu Jul 14, 2011 10:22 pm
dragrdan wrote:I know it is close, but there has to be a specification.
Dan,
Here's a trick you can try.
Find one of the Ebay sellers who sell the re-man H&Rs and send him a note asking him how tight they hold the tolerances to, mention that you are curious about the quality control in the process of machining.
One who knows his product can tell you and most should not get bitchy or offended.
