350k Should I pull the head?
Postby MrWinkey » Wed Jul 20, 2011 7:36 am
Topic says it all.....
After 350k I have a leaking freeze plug. I cant replace it with the turbo/exahust on the motor so I'm going to upgrade/replace both of them at the same time.
Should I even mess with pulling the head or just let it ride? It seems to be doing OK so far....
Thanks agian!
92 Dodge Cummins NV4500
07 Jeep Grand CRD
MrWinkey
Re: 350k Should I pull the head?
Postby skilletky » Wed Jul 20, 2011 8:48 am
if it aint broke, dont fix it. if yer not gonna be pushing more than 45 psi, you should be ok. but every truck is different. my factory head gasket lasted at 45 to 50 psi for almost 2 years, but it finally gave up. there were other factors that contributed to the failure though.
skilletky
Postby oldestof11 » Wed Jul 20, 2011 1:12 pm
At least retorque the head bolts. IIRC, if 1 goes 1/4 turn more than the rest, replace it. It is stretching at that point.
Postby dpuckett » Sun Jul 24, 2011 10:14 am
If you are just having the leaking freeze plug, I'd leave the head alone. If your oil and water are where they belong, and you arent getting any funny noises accelerating, you should be good to go.
Postby Greenleaf » Mon Aug 08, 2011 3:37 pm
That is when mine blew./ Just blew. No warning. No hot-rodding; just let go. The compression in the overflow tank tells the tale........
I parked the rig for one year as I wasn't going to half it. One year to the month I replaced the head at 350K and havn't looked back. I bought a new one, along with bolts /60 lb springs and exhaust manifold. I really hate to do the same job twice.
If you don't want to buy new, you will pay dearly in the cost of labor to machine it, clean it,inspect it, mill it etc.etc.etc. And, you still have to do the same work as if you'd bolt on a new one.
Greenleaf
tech specialist/mod
