Single stack, no muffler
Postby Ironforger » Sat Jul 23, 2011 11:23 am
My factory exhaust is rusting & on it's last leg. I'd like to replace with a 3.5" or 4" single stack system, no muffler.
Recomendations? It looks like it should be easy finding the straight stack and guard, but what about the various bends i'll need from turbo to stack?
Thanks!
FOR SALE --> 1990 W250 5sp reg cab. 21 mpg. Aprx 145k. (odo broke last year) Fuel screw. KDP killed. Solid floors, rockers & cab corners. Pm me.
FOR SALE --> 1995 Izuzu NPR 16ft Morgan body/side door. 160k. 80 k on reb auto trans. 1 ton lift gate. Pm me.
2002 3500 6 sp Qaud cab 2 wd. 202k <-- One badass truck!
1999 VW beetle tdi. PP520 injec. Rocketchip st. 3. 45 mpg. 260k
Ironforger
Re: Single stack, no muffler
Postby bwise636 » Sat Jul 23, 2011 12:24 pm
Pure deisel power has a nice 4in. Down pipe that i just installed that fits great. They also have the rest of the odds and ends you'll need to get it done.
93 club cab 350 auto: steel forward planitary /custom intake/ denny t afc delete/pump tweaked/ 4" turbo back straight piped/ DNR tps delete JUST GETTIN STARTED
bwise636
Postby Richie O » Sat Jul 23, 2011 2:28 pm
The very best deal on exhaust systems is through TV Diesel. They have complete Diamond Eye 4 inch systems for 275 delivered. If your going with a stack its still cheaper to get the whole system and use what you need then keep the rest. I know lots of people that have bought just a 4 inch downpipe for over 200 then pay shipping on top of that. On my 93 I used a diamond eye system and hooked a set of stacks to it. I have the extra pipes in case I ever need some, or I could also switch it over to a regular system if the mood ever strikes.
Postby Ironforger » Sat Jul 23, 2011 5:38 pm
Great suggestion Richie O.
So the TV Diesel kit will have enough bends to do 1 stack? If I go for it, just wondering if I'll need anything else considering the pipe is going out sideways instead of straight back.
Also, should I put a short piece of flex pipe in there somewhere to soak up the engine torque movement?
Thanks
Ironforger
Postby Richie O » Sat Jul 23, 2011 6:54 pm
You will need some flex pipe to get from the intemediate pipe to the bed stack. I used about a 3 to 4 foot section. On my 93 I used the muffler from the kit too. I loved the straight pipe sound, but it was a little to loud in town.
Postby Ironforger » Sun Jul 24, 2011 5:52 am
Good info Richie.
Where did you put the muffler? Is there room for it if you do a single stack?
Also wondering where you found the flex pipe. I found this vendor, looks pretty reasonable: http://store.airflo.com/ss4.html
Thanks!
Ironforger
Postby Hansen01 » Sun Jul 24, 2011 9:15 am
not to interupt this thread, but do you know the cheapest place to get a 3 to 4in flange?
Under construction...
Hansen01
Postby dazedandconfused » Sun Jul 24, 2011 10:07 am
Click the link in the post above you. Look threw there catalog they have what you need.
Postby Hansen01 » Sun Jul 24, 2011 10:13 am
thanks!
Hansen01
Postby PToombs » Sun Jul 24, 2011 3:15 pm
If you have a big truck shop near you they may have a piece of flex they'll sell you reasonable. Bettert then buying a 10 foot length or something. I only have a foot of it in my '97.
Postby Richie O » Sun Jul 24, 2011 7:31 pm
The only way I got the muff to fit was because it is an extended cab. I could not do the same thing in a reg cab truck. On my ex cab I put the muffler on the intermediate pipe and at the end off the muff it was right to jump straight up to my stack hook up. On another 89 reg cab truck I had with a single stack I came out of the muff, turned 180 degrees back twords the front, then hooked to it that way. ( the muffler outlet was just before the axle ) I got my flex at a heavy truck parts supplier. In my case I got it by the foot. You may even find it at NAPA. I know they can get it.
Postby Richie O » Sun Jul 24, 2011 7:33 pm
Hansen01 wrote:not to interupt this thread, but do you know the cheapest place to get a 3 to 4in flange?
I got a HX40 style 4 inch flange and v band clamp from JKIDD. He runs Diesel Auto Power. There is a link in the " Members Endeavor " section. He may have what you need.
Postby Hansen01 » Sun Jul 24, 2011 7:35 pm
ok thanks :D
i also got my flex tube from napa, they had it on hand
Hansen01
Postby Ironforger » Sun Jul 24, 2011 7:45 pm
Thanks guys.
I have a utility body, so I'm not going up through the bed. My stack will be tucked between the passenger side door pillar and the utility body. That's why I want to go with either 3.5 or 4. Not a tremendous amount of room to work with, and I may need to move my util body back an inch or so.
As for the flex pipe, 1st choice is stainless, but I may settle for galv.
Ironforger
Postby Hansen01 » Sun Jul 24, 2011 7:48 pm
i know the napa we have can order it
Hansen01
