fuel shutoff solenoid
Postby Hansen01 » Sun Jul 24, 2011 9:39 am
so dads truck would not shut off last night.. gotta be the fuel shutoff solenoid right? ignition is still working correctly so it is not that, jus thought i would make sure affor we bought one :? thanks! :wrench:
Under construction...
Hansen01
Re: fuel shutoff solenoid
Postby PToombs » Sun Jul 24, 2011 3:17 pm
Yup, that's the problem, probably chipped the tip of it. ;)
Postby Hansen01 » Sun Jul 24, 2011 5:32 pm
alrighty thanks for the assurance, il see if i cant get one ordered tomorrow :?
Hansen01
Postby Knoberman » Sat Jul 30, 2011 11:54 am
In the process of doin some searchin does anyone know of a solenoid that handles bein turned up. Mine died and its not very old quit right after the dennyt pin went in
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
Postby Hansen01 » Sat Jul 30, 2011 2:26 pm
we got it in today, there was a tiny chip in the end of it, whats that have to do with anything? but i dont think that was the problem,lol it wont go down at all, its stuck pretty tight :D
Hansen01
Postby 1STGENFARMBOY » Mon Aug 01, 2011 9:05 am
Hey Pete didn't i see somewhere where someone ground off the rubber and put a champher on what was left of the metal
part of the FSS and it worked just fine.
I did do a search but i could get nothin.
Dar
Postby ellis93 » Mon Aug 01, 2011 10:55 am
Postby PToombs » Mon Aug 01, 2011 5:20 pm
I ground mine down, then I saw the hole thru the end of it. So I welded it up, cleaned the end off smooth and put it in. It's been in about 2 years now, and it shuts off 99% of the time. Sometimes after I warp on it it will sit there and keep barely turning over and I have to stall it. But not often.
