No Power Uphill
No Power Uphill
Postby collegekid » Sat Aug 06, 2011 3:32 pm
I had previously posted about a problem that happened to me that felt as if the clutch was slipping....Well today I got back on the highway and the same thing happened again, except I saw puffs of white smoke coming from the tailpipe, going downhill I have no problems, only uphill, (I have a tick over 1/4 of a tank) my thoughts and assumptions are that the pickup in the fuel tank is not getting the required amount of fuel, does this sound about right? If so, what is a permanent fix to the problem.
collegekid
Re: No Power Uphill
Postby ellis93 » Sat Aug 06, 2011 4:16 pm
Have you added fuel to see if the problem goes away. That would be the very fist thing to do.
Re: No Power Uphill
Postby Hansen01 » Sat Aug 06, 2011 4:38 pm
lift pump goin bad? when mine was i could park on a steep hill and it would almost die
Under construction...
Hansen01
Re: No Power Uphill
Postby collegekid » Sat Aug 06, 2011 9:05 pm
I doubt its the lift pump, I just installed one about 500 miles ago, Ill fill it up in the morning and see if that solves it, if it does, Ill be looking into dropping the tank and installing a sump or draw straw, whichever y'all think is best
collegekid
Re: No Power Uphill
Postby collegekid » Sun Aug 07, 2011 11:09 am
found the culprit.....there was a piece of 1/4" tubing that the previous owner had used to patch a crimped piece of the original fuel line, I replaced all the fuel lines with 3/8" I.D. Line and left the truck with a 1/4 tank and romped it up and down the hills around here and couldn't get it to choke up, hopefully those lines fixed it for good.
collegekid
