HE351
HE351
Postby collegekid » Mon Aug 08, 2011 6:05 pm
Am looking at purchasing a turbo off a 05 dodge, what turbo is this and how hard is the install?
collegekid
Re: HE351
Postby BILTIT » Mon Aug 08, 2011 6:20 pm
It will be an HE351 yup. Requires changing the turbo to IC piping, adapter for the exhaust and possibly the intake.
Derek B.
BILTIT
Re: HE351
Postby collegekid » Mon Aug 08, 2011 6:46 pm
Ive read the compressor side might need to be clocked 100 degrees, and that Ill need a 3" - 2.5" IC boot, unless I just upgrade to 3" IC tubes...The turbo comes with an exhaust elbow, what about the bolting to the manifold and running the elctronics?
collegekid
Re: HE351
Postby BILTIT » Mon Aug 08, 2011 8:16 pm
You can use this so you dont have to clock it. I have one but havent tried to install yet.
http://www.dieselautopower.com/product_ ... 20boot.htm
electronics only need 12v or you can remove solenoid and cap it,
Derek B.
BILTIT
Re: HE351
Postby collegekid » Mon Aug 08, 2011 9:49 pm
Can you tell me the purpose of this turbo having power, I dont have the turbo in front of me or else I could prolly tell, is it to control the wastegate or geometry of the vanes or what
collegekid
Re: HE351
Postby collegekid » Mon Aug 08, 2011 10:51 pm
ok, after much research, the 12v power is put in place to control the wastegate and its dumping of excessuve boost back into the compressor side housing. Therefore, if I didnt hook up the solenoid, and pinched the line going to the wg, I should get a higher boost number bc no air is being pulsed back into the housing...am i on the right track
collegekid
Re: HE351
Postby BILTIT » Tue Aug 09, 2011 5:43 am
Yes, or you can use a boost elbow to restrict the air to the wastegate actuator.
http://www.dieselautopower.com/product_p/boostelbow.htm
http://www.dieselautopower.com/product_ ... tapped.htm
Derek B.
BILTIT
Re: HE351
Postby collegekid » Tue Aug 09, 2011 7:33 am
Thanks Biltit, it looks like for an extra $100 or so bucks I can have a better looking, more customizable setup, Thanks for the help
collegekid
Re: HE351
Postby BILTIT » Tue Aug 09, 2011 9:32 am
Which setup are you refering to, the HE351 or something else?
Derek B.
BILTIT
Re: HE351
Postby collegekid » Tue Aug 09, 2011 11:45 am
the HE351, with taking the solenoid out and installing the boost elbow
collegekid
Re: HE351
Postby Mark Nixon » Tue Aug 09, 2011 10:07 pm
WHICH HE351?
HE351CW or HE351VE (VGT)?
The CW is a vacuum/pressure gated turbo, whereas the VE is electronically controlled with a servo mounted to it.
An '05 should be an HE351CW.
