Fixed one thing and now new problem....Help
Postby 12VCrewCab » Fri Aug 12, 2011 6:24 pm
So just finished up getting the rear main seal fixed on my 93 ITD with 47RH. Drove fine for around 25 miles or a little better and came home today and let the truck run in the driveway to cool down a bit and noticed an odd noise. The truck started to lope heavily and slowly shut down. When I went to start it back up it wanted nothing to do with it and wouldn't unless I gave a little pedal. Wouldn't idle but does now after running it up for a bit but still has a lopey idle and just isn't running right. No fuel in crank case that I can tell, and does not smoke while running. I'm still new at this whole troubleshooting diesel so I need your guys help please. I just want to enjoy driving my truck.
Thanks for any help you can give.
85/93 Crewcab cummins 4x4 short bed
1938 International K1Panel w/Dakota 3.9L V6
1966 Barracuda
1969 Dart 340
1992 Dakota lowered Custom
12VCrewCab
Re: Fixed one thing and now new problem....Help
Postby ellis93 » Fri Aug 12, 2011 7:00 pm
How long did it set while repairs were done. Your fuel filter might have stopped up. That would be the simplest thing.
Postby 12VCrewCab » Fri Aug 12, 2011 7:12 pm
The truck sat for around 3 weeks before I drove it yesterday when it ran fine then this morning for a bit and then the blahh. I haven't changed the fuel filter yet but I do have a new one sitting here i'll try tomarrow. Thanks for your reply Ellis.
1966 Barracuda
1969 Dart 340
12VCrewCab
Postby ellis93 » Fri Aug 12, 2011 7:18 pm
Reason I asked was plastic fuel tanks tend to build condensation on the inside walls when half empty. You may have sucked up a little water or worse algae.
Postby 12VCrewCab » Fri Aug 12, 2011 7:41 pm
Ok thanks for the info. I'll give the new filter a go this weekend. I hope its that simple :)
1966 Barracuda
1969 Dart 340
12VCrewCab
Postby 12VCrewCab » Sun Aug 14, 2011 7:58 pm
Well thanks soooo much for the advice Ellis. Threw the new fuel filter on and pretty much fired up a ran great. I got alot of learning to do :oops:
1966 Barracuda
1969 Dart 340
12VCrewCab
