mech. or elec. fan?
mech. or elec. fan?
Postby RumbleFish » Fri Aug 31, 2007 8:15 pm
So when my fan hit the radiator, it bent some of the blades. It seems to me that it is just the end of the blades, not the support vane. I think that it would be simple to fix, but if the girl I hit is found at fault, then I could upgrade to an electric unit on her dime. What do I need to know about converting it? I like the potential for increased mileage with the electric piece, but will it keep it cool enough? I was thinking somebody just did this, but I can't remember for sure. Working 70 hours a week and wrecking the best damn truck ever built will do that to you though.
Postby PToombs » Sat Sep 01, 2007 3:54 pm
I thought I read that the electric won't draw enough CFM's to cool very good. I think there is a good thread on this on TDR.
Postby wannadiesel » Sat Sep 01, 2007 5:46 pm
An electric will cool a play truck no problem. If you use the truck to tow, you ought to stick with a mechanical fan.
Best dyno: 408/844
wannadiesel
diesel guru
Postby RumbleFish » Sat Sep 01, 2007 6:29 pm
I tow, but not real heavy. The most I tow regularly is my SRT4 in a 24" enclosed. Maybe 6k at the most, but I guess it pulls harder since it is an enclosed trailer. You guys think that is too much for the electric unit?
Also, while I throw this thing back together, what should I use in the way of antifreeze? Anything special/specific? What mixture?
Postby Begle1 » Sat Sep 01, 2007 10:22 pm
Does the electric fan get much of a performance increase?
The mechanical fan isn't much of a power stealer as long as the clutch isn't locked up, right?
On a related rate, is there an overtemp idiot light? I think that my fan clutch is defective, and it'd probably be cheaper for me to grab a couple electric fans from a junkyard than it would be to get a new fan clutch...
Postby BEARKILLER » Sun Sep 02, 2007 9:10 am
As far as the mechanical fan consuming a significant amount of power, I have a couple of trucks running PINNED-CLUTCH direct-drive fans.
I can tell no "seat-of-the-pants" difference in power, either before pinning, or after, nor have I seen any effect on fuel mileage.
In desparation, I pinned the fan-clutch on the wife's truck, after having THREE in a row brand-new NAPA bad right out of the box, to the tune of around eighty bucks.
I got my money back from NAPA and drilled/pinned her old fan-clutch.
Now, the A/C blows just as ice-cold when sitting still idling, as it does going down the road at speed.
I would figure that an electric fan set-up will cool as effectively as a clutched fan; but, I doubt the electric can keep up with a direct-drive fan.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby Begle1 » Sun Sep 02, 2007 2:32 pm
How do you know the clutches were bad?
Postby michigandon » Wed Sep 26, 2007 6:55 am
I'm running a '93 drivetrain in a 12,000lb motorhome with a custom aluminum radiator and a 3300 CFM Zirgo electric fan. If the radiator has even the slightest amount of airflow across it...even if the coach is only going 15MPH...the coolant temperature never goes over 190. The fan NEVER comes on unless stopped in traffic for more than 10-15 minutes.
11000+ miles on this setup so far with NO trouble outta the cooling system. 8)
1973 Travco 270 Motorhome repowered with 6BT/518 out of wrecked '93 D250 (SOLD :()
michigandon
Look at these stumbled across this
Postby roxxx » Wed Sep 26, 2007 7:19 pm
I used this type of fan in my old vet . This just come out, not sure if this will fit but there is one more all purpose that flows even more cfm on the web site. if you find one of these make sure it has the (S) blades they work way better had a mech one of these to that did a super job
http://www.flex-a-lite.com/auto/html/262-diesel.html
This is the Universal Truck Fan guess its new to
http://www.flex-a-lite.com/auto/html/universal.html
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Re: mech. or elec. fan?
Postby ofcmarc » Thu Sep 27, 2007 4:26 am
RumbleFish wrote: I like the potential for increased mileage with the electric piece, but will it keep it cool enough? I was thinking somebody just did this, but I can't remember for sure.
I believe it was MHUPPERTZ (sp?) I know he's on DTR and I'm pretty sure he's over here too.
'92 W-250, Getrag, Pump Tweeked, 366 Spring, Fuel Pin Spun, 14cm W/G, 3.5in Exhaust, Pyro/Boost Gauges, Front End Leveled, 202K
ofcmarc
one bonus to any electric fan in winter
Postby roxxx » Thu Sep 27, 2007 7:05 am
I know I was pushing the idea around with my 2001 truck . The fans do not free wheel when the truck is idling so it will stay hot in the winter . lol now i know some of you may laugh but some of us weather challenged people have a bit of a problem with that . Faster warm-ups and constant heat which means better mileage would be nice considering my 2006 needs to have weather front even in the fall
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby swampthang » Fri Sep 28, 2007 8:44 pm
hi i just did a right up on elec fans on a first gen they cooled better than the factory direct drive and were pretty much a bolt in check out rcc for more info
JC
Bloody Knuckle LLC
Transport,custom fabrication and used parts.
Based out of Halltown Mo 65664
JC
bloodyknucklellc@gmail.com
swampthang
Postby Begle1 » Fri Sep 28, 2007 9:59 pm
Riverside Community College?
Postby Murdawg » Sat Sep 29, 2007 5:34 am
I put two electric fans on mine also. Only one is turning on and it still never gets hot. I was reading something on flexalite fans for the newer dodges and it said it saved like 27 hp.
Murdawg
