skilletky wrote:you also have to get yer rocker pedistals machined with the arp studs.
Hansen01 wrote:are the later 12v studs the same as ours?
dazedandconfused wrote:All the 12Vs need the pedistals milled from my experience.
dazedandconfused wrote:They hit the valve cover or rocker cover depending on what you want to call it. You can clearence the covers with a die grinder as well but I've heard it's a pain.
