Gottta noise
Gottta noise
Postby thumpertrev » Sat Oct 29, 2011 1:42 pm
Not sure where to post this question as I dont know whats at fault. Mods move this if ya have to. Anyway...Under part throttle acceleration I have a noise coming from what sounds like the lower end. Its rhythm is matched by the speed of the engine. I can only reproduce this noise while I'm driving. If I put the same load on the motor with the brakes on at 0 mph in gear...no sound. Rev the motor in park... no sound. Rechecked my valves and all are properly adjusted. I put a hose to ear on each valve cover and they all sound the same. Im hoping its the flexplate as Im going to order one in about 10min. anyway. What are your thoughts Cummins guru's?
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Re: Gottta noise
Postby Tacoclaw » Sat Oct 29, 2011 4:23 pm
What does the noise sound like?
Clanging, knocking, tapping...?
Re: Gottta noise
Postby thumpertrev » Tue Nov 01, 2011 7:08 am
Sorry i havent got back. The storm killed us up here. It sounds like a light knocking.
thumpertrev
Re: Gottta noise
Postby Hansen01 » Tue Nov 01, 2011 7:50 pm
would say a valve, but since it doesnt do it when idling you might be on the right track
Under construction...
Hansen01
Re: Gottta noise
Postby collegekid » Wed Nov 02, 2011 3:52 pm
Check for something loose, like the exhaust on the tranny, or maybe a motor mount, my exhaust would do that to me, drove me nuts till I got under there and noticed it touching. But like yours, I couldnt reproduce the noise, only while driving would it do that
collegekid
Re: Gottta noise
Postby thumpertrev » Mon Nov 07, 2011 9:58 am
Well, started hearing it idling in park so I climbed under it with a tube to ear. Loudest at the flexplate. New one on the way. Will let you know what happens.
thumpertrev
Re: Gottta noise
Postby thumpertrev » Sat Nov 12, 2011 10:55 am
Well I guess I'll chalk this up to a lesson learned. Here's my friday night schooling.
#1. Ebay SFI flex-plates ARE too good to be true.
#2 Apparently the previous owner of this engine had already advanced a tooth on the pump.
#3 You can hear what sounds to be a cracked flex-plate when the timing is too far advanced. Retarded my timing and the truck runs better, smokes less, and NO MORE KNOCK!!!! :jumpsmile:
thumpertrev
