Which one for the heater?
Postby Broncman » Mon Oct 31, 2011 5:13 pm
Which coolant ports for the heater core? Got the one on top of the motor above the t stat housing, one on the block below the t stat and one even lower??
Which one do I plumb the heater core with?
Alls the stock stuff had been removed and plugged.
Broncman
Re: Which one for the heater?
Postby BobS » Tue Nov 01, 2011 4:21 am
The top one that you noted and the lowest one near the lower radiator hose connection. You want the suction side of the water pump to aid in pulling the coolant through the heater core.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Broncman » Tue Nov 01, 2011 5:42 am
Thanks!
Broncman
