TRENDZ wrote: It just has me wondering what a more normal truck operates as far as boost/egts.
TRENDZ wrote:What boost levels and/or egts are you guys seeing at a steady 65-70 mph? I'm curious. My truck has 3.08 rear gears, a 518(od) trans with a goerand converter. At 70mph i'm at 9-10 psi and 700 degrees. I can open up my turbo (351 vgt) and drop the boost, which raises the egts. It just has me wondering what a more normal truck operates as far as boost/egts.
JustinRhodes wrote:TRENDZ wrote:What boost levels and/or egts are you guys seeing at a steady 65-70 mph? I'm curious. My truck has 3.08 rear gears, a 518(od) trans with a goerand converter. At 70mph i'm at 9-10 psi and 700 degrees. I can open up my turbo (351 vgt) and drop the boost, which raises the egts. It just has me wondering what a more normal truck operates as far as boost/egts.
I also have the 351ve, not on the truck atm. i saw 6-7psi cruising with my turbo not closed down really far. curious as to how your turbo is controlled. have any pics, video or anything of it?
TRENDZ wrote:It just has me wondering what a more normal truck operates as far as boost/egts.
TRENDZ wrote:JustinRhodes wrote:TRENDZ wrote:What boost levels and/or egts are you guys seeing at a steady 65-70 mph? I'm curious. My truck has 3.08 rear gears, a 518(od) trans with a goerand converter. At 70mph i'm at 9-10 psi and 700 degrees. I can open up my turbo (351 vgt) and drop the boost, which raises the egts. It just has me wondering what a more normal truck operates as far as boost/egts.
I modified the control section to accept a reversable DC motor, controlled manually by a momentary open/close switch on the dash, instead of the stepper motor that is on them originally. It works real nice.
