thrashingcows wrote:Well when was the last time of a valve adjustment? Usually you won't get a miss though with valves out of adjustment. Might be a bad injector? Try cracking open each injector while it's running and listen for the tone of the engine to change. If it does not change then you have a dead injector.
VanillaGorilla wrote:I'm having this problem, went to leave the jobsite the other day and there's about a 6" round wet spot under the motor, damn. fire it up and go to leave and at about the same spot un the throttle you mention it's missing and would smoke a light color if I stayed in it too long. Baby it home and find I have a fuel leak sucking air and it's the same symptoms as a bad injector but the leak tells me that's the problem, look it over good.
oldestof11 wrote:My solenoid on my injection pump was going out and produced the same problems.
oldestof11 wrote:Mine went out about 2 months before I started having problems.
Mine I think was due to a poor electrical connection. Andrew can vouch for that. I definitely lost top end. I had just installed the 4200 rpm spring and we got to romping on it when we left SOP. Mine fell so hard on its face it was worse than the 1.6L IDI VW diesel I had with all of its mighty 52hp...
We pulled over and I wiggled the connection, viola! I had my full rpm range back.
About a couple weeks later, my truck start mising, no power above 2000rpms and if it did get up there, it would buck and surge. I pulled into my parents drive, got out the chisel, and 20 mins later, it was gutted. I cut the 2 ends off the electrical wires there and added some male/female spades to connect them.
