Oil pressure at idle
Postby Broncman » Fri Nov 18, 2011 8:44 am
What is normal oil pressure at idle?
Broncman
Re: Oil pressure at idle
Postby ahale2772 » Fri Nov 18, 2011 9:52 am
HOT HOT HOT with 15-40 rotella I see 23 at the lowest
Postby m880cummins » Tue Nov 22, 2011 6:27 pm
I get around 22 on a mechanical gauge at coolant temp of 180 degrees. Cold it runs about 50ish. I can't quite remember off the top of my head...
SUNY Maritime Class of 2017!
m880cummins
