What is the drain hose by the starter and oil pan?
Postby Diesel » Mon Nov 21, 2011 10:09 am
There is a drain hose by the starter and oil pan that has steamy material coming out of it while running and leaves a small spot when parked. It is not attached to the fuel filter. What is that venting? PCV?
1991.5 D250 Intercooled A518
Diesel
Re: What is the drain hose by the starter and oil pan?
Postby skilletky » Mon Nov 21, 2011 10:11 am
Crank case vent. Is there alot of smoke coming out of it
skilletky
Postby Diesel » Mon Nov 21, 2011 10:21 am
No there is barely anything coming out of it. Just a little steam at times but not much of anything.
Diesel
Postby skilletky » Mon Nov 21, 2011 2:25 pm
That is a good thing. How many miles are on the truck
skilletky
Postby Diesel » Mon Nov 21, 2011 2:33 pm
I believe 156K on the truck. I am glad that hose isn't supposed to go to anything and is just PCV.
Diesel
