P.s. I know I'm an idiot, no need to tell me now.
KTA wrote:FWIW I ran into this issue before and helicoils would not hold. If it was me i would go 9/16 to fix it as that will totaly clean out the messed up 12mm threads and a 14 won't do that. Problem is you will have to drill out your head to to clear the bigger bolts. I put another block in the truck i worked on to fix it.
