blue smoke
blue smoke
Postby BAD HABIT » Sun Nov 27, 2011 8:05 pm
My truck has started to let out blue smoke,i just noticed it leaking oil out of the turbo housing by the down pipe?? help lol
79 f150 4x4 on 44s with a 12 valve
BAD HABIT
Re: blue smoke
Postby BAD HABIT » Mon Nov 28, 2011 9:08 am
Ok it was late when I posted that,its blow by,but now what tear it down and put rings in it,or is there maybe an evac tube cloged??
BAD HABIT
Re: blue smoke
Postby BobS » Mon Nov 28, 2011 9:52 am
I always start checking in order of the cheapest fix to the most expensive. I would start by removing the intake cross over tube and check for an accumulation of oil coating the inside. That would indicate a turbo seal thats letting lube oil enter the intake.
Then next in order I would check the crankcase breather for excessive oil leaking from the tube. This would indicate a problem with a cylinder leaking such as a cracked ring, galled cylinder, cracked piston, or a combination there of.
Then I would run a compression check to confirm the cylinder problem.
You need to find and confirm the source of the problem BEFORE you start ordering the parts to fix it.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: blue smoke
Postby ahale2772 » Mon Nov 28, 2011 9:52 am
could be yes, check the breather off the tappet cover
