need ideas of whats wrong with pump.
Postby JustinRhodes » Sat Dec 03, 2011 8:15 pm
I believe i have narrowed my problem down to the pump itself. Ive replaced fuel filter,injectors, feed/return lines, removed plunger in shut off solenoid, installed low pressure piston lift pump, installed fuel pressure gauge, and checked to make sure afc was working. All of that and it still isnt working right.
Now let me explain what its doing. Has a little miss around half throttle, has no middle-top end fuel, kind of surges so to speak when boost comes in.
So does anyone have any ideas what could possibly be wrong with my pump?
Ive spent many hours fooling with the truck trying to fix the problem, ive got it narrowed down this far and I want to get it running back to the way it was so i can say i fixed it. Then on to the pee pump :lol:
Any help is appreciated.
JustinRhodes
Re: need ideas of whats wrong with pump.
Postby cmann250 » Sun Dec 04, 2011 7:14 am
How many miles are on the IP? Somethings just get worn out and need a rebuild
Postby JustinRhodes » Sun Dec 04, 2011 7:51 am
cmann250 wrote:How many miles are on the IP? Somethings just get worn out and need a rebuild
Unsure, i replaced the one that was on it because it was messed up. This is just a used one that came off a buddies truck after he pee pumped it.
JustinRhodes
Postby oldestof11 » Sun Dec 04, 2011 8:04 am
Did you check to see if the AFC cone was still bolted to the diaphragm?
Also, anything missing from the tip of the FSS plunger?
Postby cmann250 » Sun Dec 04, 2011 8:07 am
Well i could be completely talking out my rear end here, but it sounds like the vane pump inside the IP is worn out and not keeping up. If i understand correctly, it sends fuel where it needs to go within the pump
Postby JustinRhodes » Sun Dec 04, 2011 8:07 am
oldestof11 wrote:Did you check to see if the AFC cone was still bolted to the diaphragm?
afc cone was still bolted down yes, and the FSS plunger looked brand new to my suprise.
cmann, I am unsure of the internal workings of the ve pump, however that sounds like it very well may be my problem. It acts like its running out of fuel when i have 20 psi too it.
JustinRhodes
Postby dazedandconfused » Sun Dec 04, 2011 8:12 am
What about the pin that rides on the fuel cone is it moving or stuck in?
Postby JustinRhodes » Sun Dec 04, 2011 8:17 am
dazedandconfused wrote:What about the pin that rides on the fuel cone is it moving or stuck in?
Thats what i meant when i said i checked the afc, yes it is moving like it should. Thats first thing i checked for because thats one of the problems with my old pump :oops:
JustinRhodes
Postby oldestof11 » Sun Dec 04, 2011 8:28 pm
Now, just because an electrical component looks good, don't mean it is good. ;)
Take the plunger out and set it aside. Report back. This does sound like my truck when the plunger and solenoid took a crap.
Postby JustinRhodes » Sun Dec 04, 2011 8:36 pm
oldestof11 wrote:Now, just because an electrical component looks good, don't mean it is good. ;)
Ive already joined the pull cable club :lol:
Anymore idears?
JustinRhodes
Postby cmann250 » Mon Dec 05, 2011 5:50 am
I have to wonder if you are really going to P7100 this truck, why do you want to fix the VE?
Postby ahale2772 » Mon Dec 05, 2011 6:33 am
there is nothing wrong with the pump, its just that you keep talking about a P7100.... :lol:
my truck develops an oil leak, engine knock and flat tires every time I think about getting something different...
SHHHHHHH, it can hear you talk!!!
Postby ellis93 » Mon Dec 05, 2011 7:49 am
Anymore idears?
But did you take out the plunger? It could restrict fuel.
Postby dazedandconfused » Mon Dec 05, 2011 1:18 pm
ahale2772 wrote:SHHHHHHH, it can hear you talk!!!
:lol: You know I've said that for years! It's like a dang woman soon as you open your mouth or look at another they start giving you crap.
Postby JustinRhodes » Mon Dec 05, 2011 8:40 pm
cmann250 wrote:I have to wonder if you are really going to P7100 this truck, why do you want to fix the VE?
I've spent many hours and a good bit of money chasing this problem. Its personal now and i will fix it whether it be in the truck or not :twisted:
Dazed, yes i have removed the plunger fully.
ahale2772 wrote:there is nothing wrong with the pump, its just that you keep talking about a P7100.... :lol:
I might start sweet talking it :lol:
JustinRhodes
