i also hav some sort of disturbing noise
Postby ciamcoop » Sat Dec 10, 2011 6:41 am
Truck has 253k on it, pump cranked etc. The noise started when I was spanking a duramax, about 3000-3100 rpm and all of a sudden it started rattling. I shut it down and checked it all out, no bubbles in radiator, it blew a little oil out dipstick but not a lot, and it was missing. I cracked injector lines and found number 6 to be the hole with the problem. When I cracked injector line the engine didn't change sound. I'm hoping for the best so I pulled the injector, it wouldn't blow it put by cranking it so I made a puller and it came out. I took it apart and checked and cleaned all the parts. It looks like it has some wear on the plunger thing inside but I don't know. I put it together and put injector back in but didn't install the hold down nut, I cranked the engine and it blew the injector out with a lot of force so I'm thinking I still have good compression. I put everything together and fired it up. The misfire is gone but it still has the rattle/knock in it. It does have a little smoke at idle now. When I crack #6 injector line the rattle/knock goes away. I'm wondering what you guys think, I'm thinking maybe the injector isn't closing totally so it's dripping fuel? I ordered injectors but don't want to put em in and not be able to maybe return them. I'm nervous it's something serious and I'm 1300 miles from home. Sorry about the long post but let me hear your thoughts.
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Re: i also hav some sort of disturbing noise
Postby ciamcoop » Sat Dec 10, 2011 7:12 am
Guess I could've read down a few more posts, sounds about like mine. I haven't swapped injectors around yet but I think I'll try it.
ciamcoop
Postby Hansen01 » Sat Dec 10, 2011 10:58 am
i think your on the right track :D
Under construction...
Hansen01
Postby ciamcoop » Sun Dec 11, 2011 4:21 pm
Well I got my new 5x14s in but the knock is still there. I guess I'm probably looking at a broken piston, wrist pin or rod bearing. This is not really what I was looking forward to. Anyone know where the best place to start looking for rebuild kit is? On another note the engine is much quieter running now, aside from the knock.
ciamcoop
Postby dazedandconfused » Sun Dec 11, 2011 4:45 pm
Have you checked valve lash on it? I'd run the valves and see if it helps.
Postby ciamcoop » Sun Dec 11, 2011 5:05 pm
I'm at work in bfe Colorado on an oil rig right now and can't find anyone with feeler gauges, but I did roll the engine over and kinda check them by hand. They all seem ok, some feel a little looser than others but none seemed really loose. I get done working Wed morning and I'll get some feelers and check em.
ciamcoop
Postby ciamcoop » Tue Dec 13, 2011 8:53 am
Anyone else have any ideas? I read something about a thrust bearing somewhere that wears out and starts making noise, any details? I'm 1300 miles from home but I don't want to destroy the engine if it's something bad, but a tow bill to get it home would be more than the pickup is worth. I drove it about a mile after I put the new injectors in, the knock is quieter but still there unless I'm coasting then it's totally silent. Inside I'm thinking it's a broken piston, but what is the likelihood? 3000 rpm isn't anything to hurt these and the truck was all stock until I got it 25k miles ago. Egt has seen 1500 before but not for very long at all. What would you guys do? Btw I'm around Greeley, CO and am heading back to OR if it matters to anyone.
ciamcoop
Postby Hansen01 » Tue Dec 13, 2011 4:19 pm
ever get feeler gauges on it?
Hansen01
Postby ciamcoop » Tue Dec 13, 2011 4:23 pm
Not yet, I leave here in the morning after I'm done working.
ciamcoop
Postby Hansen01 » Tue Dec 13, 2011 4:25 pm
make sure all your valves are moving properly threw out the rpms when u got the covers off to
Hansen01
Postby ciamcoop » Tue Dec 13, 2011 4:33 pm
Ok, oil probably gonna be going everywhere eh?
ciamcoop
Postby cmann250 » Tue Dec 13, 2011 4:48 pm
ciamcoop wrote:Ok, oil probably gonna be going everywhere eh?
Not necessarily at idle. I haven't done this with a 5.9L, but a guy i work with ran his Oliver 1955 around the barn lot without a valve cover
Postby PToombs » Tue Dec 13, 2011 5:59 pm
To do a quick check of the thrust washers just grab the balancer and move the crank in and out. I thought mine was excessive doing that so I put an indicator on it, and it was right in the middle of the spec. If the thrust is bad the crank will move alot.
Postby Hansen01 » Tue Dec 13, 2011 8:36 pm
nah i did that to mine a couple of times when we put a push rod in wrong :D
Hansen01
Postby rattlebox93 » Thu Dec 15, 2011 11:02 pm
I got a rebuild kit from napa for mine came with all the rings bearings gaskets seals ect it was all felpro and speed pro it was like 450 if i remember rite had good luck with it so far
rattlebox93
