help fix white smoke
Postby remi » Sat Dec 31, 2011 6:57 pm
i was driving up a grade and i noticed white smoke out of the stack, so i pulled over there and was no antifreeze in oil an i empty the fuel filter from the water release valve. what else should i check to help eliminate some possible problems?
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: help fix white smoke
Postby ellis93 » Sat Dec 31, 2011 8:15 pm
Was your coolant system holding LOTS of pressure when you checked it. That could be a sign of a head gasket problem :yuck:
Postby remi » Sat Dec 31, 2011 8:16 pm
how can you check that but i haven't lost any coolant
remi
Postby ellis93 » Sat Dec 31, 2011 8:22 pm
Doesn't take a lot of antifreeze to make white smoke.
Take it on a run again and feel of the top rad hose,if its hard as a brick that's not normal.
Postby remi » Thu Jan 19, 2012 11:12 am
its was a fuel filter problem solved i feel like a dumbass lol
remi
Postby CumminsPower59 » Thu Jan 19, 2012 1:35 pm
Its ok, sometimes we overlook the simple stuff, I do it all too often myself ;)
Postby thrashingcows » Sun Jan 22, 2012 2:35 pm
Thanks for posting the solution to your problem. Many times we search threads and find all kinds of advice and diagnosis...but never a final response telling us what the problem ended up being.
thrashingcows
Postby remi » Sun Jan 22, 2012 4:07 pm
no prob
remi
